11-11-2013, 07:03 PM | #1 |
Pebble Pounder Join Date: Sep 2013 Location: Pierce county
| New To Multi Axle Rigs
Hey I'm building my first 6x6 based off Crawler king axles and need some assistance with choosing a suspension design. Should I tie the rear axles together or 4 link both rears? Just finished my center drive axle. Sent From This Old Droid of Mine using tapatalk 2 |
11-11-2013, 07:23 PM | #2 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
| Re: New To Multi Axle Rigs
I did this on a 6x6 I built. Front axle 4 linked as usual, then the rear axle is connected to the front by the lower links. Then it had its own uppers as well. |
11-11-2013, 07:26 PM | #3 |
Here is a setup I am working on. Mini trophy arms, and some homemade spring jobbys. But yeah, like noob has em too. Sent from my computer-phone. |
11-11-2013, 07:30 PM | #4 |
I like that setup it looks clean and simple. Do you have any flex pics noob? Has anybody seen a traditional four link on both rears with the last axle using a reversed four link? Sent From This Old Droid of Mine using tapatalk 2 Last edited by Jakethesnake-rs10; 11-11-2013 at 07:33 PM. |
11-11-2013, 07:54 PM | #5 |
Here is a crude simple illustration of my reverse 4link idea. The blue links would be the uppers. Sent From This Old Droid of Mine using tapatalk 2 |
11-11-2013, 08:10 PM | #6 |
| New To Multi Axle Rigs Building a trial truck? Someone tried it before on here. Couple google searches and found it. Just searched "6x6 suspension" Also, try and keep the uppers parallel to the lowers in your design and parallel to the ground. Link geometry is important in any truck build. Sent from my computer-phone. Last edited by Szczerba; 11-11-2013 at 08:13 PM. |
11-11-2013, 08:24 PM | #7 |
Thanks man for shedding alittle light on that subject. Anybody have experience using a balance cart or whatever its called? Edit: walking beam? Sent From This Old Droid of Mine using tapatalk 2 Last edited by Jakethesnake-rs10; 11-11-2013 at 08:52 PM. |
11-12-2013, 05:22 PM | #8 |
So what setup is going to give me the best flex? Walking beam or a 4 link? Sent From This Old Droid of Mine using tapatalk 2 |
11-12-2013, 09:10 PM | #9 |
A 4 link, hands down. I built a 6x6 a few years ago using the Reign K2-6 chassis, which became the one that rc3wd sells. I used individual 4 link suspension on each rear axle, it worked so well I had to limit the travel on the pass through axle or else the drive shaft going to the rear axle would bind up or come apart. There's been a few builds on here where someone used a walking beam and they managed to get decent articulation out of it, but it was a lot more work than a 4 link. |
11-12-2013, 09:59 PM | #10 |
4 link it is then thanks again. Can't wait to start fabricating a frame.! Sent From This Old Droid of Mine using tapatalk 2 |
11-13-2013, 10:57 AM | #11 |
Rock Stacker Join Date: Feb 2012 Location: Israel
I'm in progress of building my second 6x6 with WK axles. I used the balance cart suspension twice and it is outstanding! I get as much articulation range as I want, well sometimes even too much. This set up is NOT spring-ed, some people mount leaf springs instead of solid connection to the chassis. Build thread: Oshkosh P-series 6x6 Truck Good luck! |
11-13-2013, 07:10 PM | #12 |
Yoraish I saw your build a few days ago its what inspired my 6x6 dream in the first place lol the pic with the flex on the fruit has been my background for awhile lmao Sent From This Old Droid of Mine using tapatalk 2 |
New To Multi Axle Rigs - Similar Threads | ||||
multi axle section | scale4x4 | Comments, Suggestions, and Help | 74 | 06-29-2013 12:05 PM |
Manny's MULTI-AXLE Project | mannyr69 | Multi Axle Rigs | 47 | 10-24-2012 01:18 AM |
NOSTR Multi-Axle Challenge! | microgoat | Scale Videos! | 10 | 03-07-2011 02:08 PM |
