Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: 6x6, My First Build.
Old 04-02-2014, 07:36 PM   #1
Default First 6x6 Build. 2.2 K2-6 Bullhead W/ Axial axles
This is not my first kit or the first time I have built something however this is the first time that I a building a more intricate project (For Me) with the intentions of enjoying the building and modeling process.
I have been working with a few people from RCC who have been very helpful to me.
So far these people include:
TheScaleAddict: The owner of "The Scale Addict", Brain, will take time to help you with all of your questions. He runs a website, The Scale Addict , and if want something he does not have he will try get it for you. Supporting businesses like "The Scale Addict" is what really keeps our hobbies going. I have purchased and will keep purchasing the bulk of my parts from them.
Monkeyracer: (Custom 6x6 Truss Kit) He built me a custom kit for a 6x6 with templates used for drilling the axle cases for the mounting hardware. More will come on this great product in the build thread. I got it for a great price and I think he will make this kit available to anyone who would like it.
JC Auto Design - SCX10/AX10 Axle Truss, Panhard and CMS options
HeyOk:
I will be buying a 3rd channel switch from HeyOK to control my lights. I will also be buying a brake light module from him as well to control my brake lights on my throttle channel.
Although I have not purchased the products from him yet because I am not 100% sure which lights I will be using, he has helped me and answered all of my questions.
Check out his page:
HeyOK's RC Electronics items (all in one place)
Finally on to the exciting part!
Work in Progress Parts list
Chassis and Accessories:
RC4WD K2-6
Tough Armor Wide Winch Bumper
Wheels and Tires:
RC4WD 2.2 Militant wheels
RC4WD 2.2 Mill Spec tires
Electronics:
Hitec 7980
HH BXLR
HH 7T
Drive Train:
Axial Axles (Partial built)
AX10 Transmission with metal gears and Spur Gear 32P 54T, 11T pinion
Suspension:
SCX10 Icon shocks for rear axles, working on front shocks right now
Xtreme RC bent Delrin lowers and strait upper links from old crawler
Body:
Tamiya BullHead
If anyone has any questions during the build feel free to PM me and I will help you as best as I can since I am learning as I go as well.
Pictures to come.
d-fly is offline   Reply With Quote
Old 04-03-2014, 10:21 AM   #2
Default Re: 6x6, My First Build.
Nice man I see you finally started lol. I bet you will finish before me I am dragging my feet. I just picked up a scx10 for the wife. I may start my bed soon tho.
cg78 is offline   Reply With Quote
Old 04-03-2014, 07:22 PM   #3
Default 6x6, My First Build.
Alright I am back!
The trusses came perfectly packaged. Each came in a separate bag and labeled. The front was the simplest install. It was just screwed in. The center axle, since it has the two drive sides of the axle, needs a extra hole drilled for the truss. The rear also needed two holes drilled since the axle was flipped. Included in both the middle and rear bag was a temple to make drilling supper easy. I used 3mm x 6mm screw to screw the truss to the axle. When the raised notch on the axle was not there I used 3mm x 8mm. I think it held better but is not necessary.
Packaging
Front axle
Here is the center axle getting ready to drill the two knew holes.
The actually truss is not completely flush on bottom. There is a notch cut out for the original notch used to hold the screws. This helps the truss have a strong bond to the axle.
In the rear however it is completely flush.
Here is the final product
More to come,
Vanquish Chub and Knuckles hopefully
Axial CVD's
Old 04-22-2014, 06:09 PM   #4
Back to building
New Parts on the way
1: SuperShafty Top shaft
2: Dlux knuckle bushings
3: Supersoft axial springs
4: RR 32P spur gear
5: VP steering linkage
I used 8-32 threaded rod to build links. I then covered the threaded rod with water line probably used for a refrigerator hook up. These links are only temporary to get a idea of what size I need. I will probably ended up buying links from vanquish
imgurl
On the front I also added axial cvds, vanquish chubs and knuckles. I also ordered the Dlux bushing kit and VP steering linkage to finish up the front.
I barley had any room to fit the motor (7T) in the chassis.
uploading images
I need to figure out how to mount the front bumper. Thinking about cutting some aluminum or using picture frame angle brackets.
image upload no limit
free image host
Next, I spent time trimming the body. I got it to fit how I wanted and at the height I wanted. I am going to try to order some earth magnets to mount it. Some pictures with the body.
image hosting over 10mb
upload images free
upload an image
Old 04-23-2014, 11:32 AM   #5
Nice job. the links man the hard part is done cutting the tubing to fit what you have is easy with a small tube cutter. You are about to catch me up soon.
Old 04-23-2014, 12:58 PM   #6
Yea. I'll ether do that or buy some really nice VP ones.
Old 04-23-2014, 08:13 PM   #7
love the build looks really close to what im doing for mine exept i doing 6ws
ben h is offline   Reply With Quote
Old 04-23-2014, 08:36 PM   #8
Attaching the bumper
Bought some corner brackets used for the back of picture frames. I then modified them so that they had a inch long slot that it could slid up and down on the screw before they are tightened for adjustment.
image hosting without account
img hosting
photo sharing websites
A little more cutting and it should be perfect.
Currently the brackets that come with the bumper (that are already attached to it) are only held by one screw. I need to drill a hole in the back of bumper for second screw. Not sure if I should 3mm tap it or just drill and hole and use a machine screw. Or just leave it with one screw.....
Old 04-26-2014, 06:11 AM   #9
looking good dude!!!!!
GEISSE-RC is offline   Reply With Quote
Old 04-26-2014, 06:49 AM   #10
You'll like driving it around ,they got their own feel to them. I built a bullhead leaf'er years back and ever time i take it out it still make me smile.
old man 52 is offline   Reply With Quote
Old 05-07-2014, 08:32 PM   #11
Started on the rear bumper.
image sharing
picture share
image hosting sites
Used a piece of angle aluminum and EPDM (roofing material) Just ordered some new aluminum square tubing and I am going to take a new one. Just a mock up.
image upload no size limit
picture upload
Super shafty top shaft with Robinson Racing 32 Pitch spur gear. Best built RC part I have ever bought. Fit amazing and is so robust that I do not think anything can break it.
Front bumper additions. Decided to do four lights on the "bull bar" I used Crawler dad Leds for the two big middle ones and two 5mm for the outer lights.
I had to wire it twice because the first time my solder joint was in a bad spot and made the wire to stiff to get under the body.
I used these P clips to attached the lights to the bull bar.
upload an image
picture hosting
free upload image
And not for the fun part. Let there be light!
gif image hosting
Completely dark room.
picture upload sites
I got all my other parts in from HEYOK. Hes a great guy and has helped me out so much. Check out all of his stuff.
I dont know where I am going to fit everything on my chassis especially with the winch controller on the way.
Old 05-09-2014, 10:45 AM   #12
Making good progress bro. I like it.
Old 05-09-2014, 10:59 AM   #13
Great looking rig so far!
Szczerba is offline   Reply With Quote
Old 05-16-2014, 04:50 PM   #14
Looks great! I have a Bullhead body that is waiting for a 6x6 build. I'm subscribed.
BigSmokinGun is offline   Reply With Quote
Old 05-16-2014, 04:56 PM   #15
Thanks! Just Re did the rear dumper. I will Post pictures after it is painted and lit up.
Are you going 2.2 or 1.9. 2.2 has been a struggle with clearance on front wheels
Old 05-19-2014, 08:29 PM   #16
So I got the bumper together and built the mounts. I really like how its coming out so I figured I would show you pictures before I painted it. Here we go.
image hosting 12mb
I built my mount again using the same bracket for the front plus I made angle brackets out of 1" by 1/2". I cut it in half and then just cut them into the length I wanted.
photoupload
image upload with preview
Here it is mounted. Right now I am waiting for my tap set to come in so I can screw it directly to the bumper without having to use a nut.
gif uploader
Old 05-20-2014, 04:36 AM   #17
I'm not sure yet. I was thinking I wanted to keep the tires under the fenders but now that I see yours, that may change. The thought crossed my mind to widen the fenders but I dont know how that would look.
Old 06-16-2014, 05:58 PM   #18
This rig is looking great! The wheel and tire combo are perfect and I like the mud flaps! Also love those puller motors I have 5 of them
ctrwannabe is offline   Reply With Quote
Old 06-21-2014, 11:17 PM   #19
Got some more work on the read bumper. Primed and painted with bed liner. Some how fit all the lights in to. Was really tight fit with wires and everything.
Replacing the front truss mount with a pan hard set up. Also going to order new links soon as well.
Working on a rack for behind the cab. Hopefully that will be done soon and more pictures to come!
Here's a little preview though.
Old 08-19-2014, 05:08 AM   #20
I have left my project at home in NY and I am currently in Melbourne Australia.
Hopefully ill get back home by the end of december. He is a video I have been meaning to post for before I left
HEY OK light controller and reverse alarm - YouTube
When I set a better throttle curve on the esc I should be able to get the reverse lights to be more constant as well as the reverse beeper since they both run off the same channel on the light controller.
Anyone have suggestions for the rear and a bed?
6x6, My First Build. - Similar Threads
The 6x6 Build! yoraish HPI Wheely King 7 08-29-2012 05:30 PM
formtheday's 6x6 build formtheday 1.9 Scale Rigs 57 11-04-2010 04:39 AM
Cant resist... My 6x6 Build Brandon 1.9 Scale Rigs 130 10-20-2007 02:51 PM
6x6 build and how to james12s 2.2 Scale Rigs 7 04-28-2007 03:42 PM
