Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Extradition
Old 08-11-2014, 03:45 PM   #1
Default Extradition
The purpose of this truck is to go anywhere the big bad brushless trucks can go and then get them out when they get stuck.
Using Wk axles and axial transmission, keeping her as light as possible,(to save axle shafts)Gpm 70 mm aluminum shocks, 1/8" x2" x 26" homebrew chassis. Also using the stock 5" Wk tires in the rear and 2.2 Tsl's up front for a slight Overdrive on the front.
How she sits now.
Next shock towers.
lonleycreeper is offline   Reply With Quote
Old 08-17-2014, 08:58 AM   #2
Default Re: Extradition
The shock towers were built then deleted, suspension is completed and trans is in. I need to make some spacers and get some longer screws to get the trans motor plate on. Chassis is being painted yellow. Body will be metallic navy blue with yellow highlights.
Old 08-17-2014, 03:13 PM   #3
Back together.
Old 08-21-2014, 10:49 AM   #4
A little C.A.D.
Cardboard aided design, lol.
Old 08-22-2014, 06:37 PM   #5
Old 08-23-2014, 09:15 PM   #6
Old 08-26-2014, 09:48 AM   #7
I narrowed the cab a full 1inch and put a bed together.
Yes that is a 2.2 Scx10 on the back.
Old 08-28-2014, 11:58 AM   #8
Mockup for my driver.
He will sit a bit lower but not much.
Old 08-28-2014, 06:25 PM   #9
you have it looking good so far, keep it going.
lewlew is offline   Reply With Quote
Old 08-31-2014, 08:14 AM   #10
Thank you. Keeping on, keeping on.
Doors are in, hinged using tape right now.
And the steering is in.
Solar d772.
Old 09-04-2014, 03:02 PM   #11
Took her for a spin in the living room today. Crawls good, just need to finish the cab/bed, mount them and mount the electronics. Getting excited about driving it.
Old 09-06-2014, 09:12 PM   #12
I knocked out a battery mount in the saddle position.
Going to run this body tomorrow.
Old 09-07-2014, 04:32 PM   #13
Got her out.
And the carnage.
Old 09-07-2014, 04:41 PM   #14
Thoughts, she needs more power.
She is very stable but rear heavy, the center axle was poping in bound situations and the skid was flexing under load. She is still geared to high, motor got to the point that I couldn't hold my finger on it. ESC was hot to. In hill climbs (loose sand) the ESC shut off a few times.
She needs some improvements for sure but that is the fun, right?
Old 09-08-2014, 10:27 PM   #15
New drive train setup.
Old 09-09-2014, 06:03 PM   #16
Threw her on a scale today, 7.5 lbs rtr. 10 lbs with the toolbox and tools.
Old 09-11-2014, 03:13 PM   #17
Picked this up today.
Old 09-29-2014, 06:44 PM   #18
Not digging my cab. I saw a Mack Terra Pro cement truck on the road, and I think I am going to copy the cab.
In other news I found some old beadlocks rings, I painted them silver, and mounted them on the axial rims
Old 10-16-2014, 02:11 PM   #19
I think I stripped a gear in the middle axle on Sunday. She won't climb a hill without "popping".
Need to tear her apart clean her up and inspect the axle.
I am going to put the build on hold for a while, going to Finish the F650 and my Pig mud truck and my Cc01.
Old 11-13-2014, 07:18 PM   #20
Some more C.A.D.
