Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Snapon' s 6x6 build
Old 04-28-2017, 10:04 PM   #81
snapon boy's Avatar
Default Re: Snapon' s 6x6 build
I've got to get on that. I have the xr10 mod in the front with over Drive gears and it dose turn well. However in a comp I need all I can get from it. How did you wore it up
149 r/c worx /scalerfab Team Driver
snapon boy is offline   Reply With Quote
Old 04-28-2017, 10:08 PM   #82
I run a spektrum DX4C so it has steering mix built in. Run it off aux2. I can turn it on or off. If you have a DX4S you can set it for front/crab/4ws
Sent from my SAMSUNG-SM-G935A using Tapatalk
wblteen is online now   Reply With Quote
Old 04-28-2017, 10:18 PM   #83
snapon boy's Avatar
I've got a airtronics Mt4. How did you connect the bec to 2 servos?
Old 04-28-2017, 10:19 PM   #84
I power my receiver off the bec.
Old 04-28-2017, 10:20 PM   #85
That's going to change once I get a second spektrum 6250 HV servo. I'll run a bypass then
Old 05-28-2017, 02:54 PM   #86
Proud DMG Stiffy Owner!
allanon1965's Avatar
snapon boy, how tight is your turning radius/circle? ...mine is at about 4.5 ft right now...
allanon1965 is offline   Reply With Quote
Old 05-28-2017, 03:05 PM   #87
snapon boy's Avatar
Idk I would guess close to that my servo is out but I'll push it in a circle and see. I did do the xr10 mod on the front
Old 05-28-2017, 03:10 PM   #88
snapon boy's Avatar
53in by hand rolling it
Old 05-28-2017, 03:13 PM   #89
wow, mine is that tight with just my usual axial high clearance knuckles and aluminum chubs, I still have the dogbone axles in the front. I was thinking about doing the narrow XR mod to try and gain some more turning,but its close to 200 bucks with the beeftubes, XR axles, vp wraith chubs and knuckles and knuckle bushings.... not sure if its worth doing at this point...
My setup ( if I put in axial cvd axles) was half that cost and turns as well...
Old 05-28-2017, 03:17 PM   #90
snapon boy's Avatar
here is the side shot to show you where the links are mounted. I don't know if it would be any tighter with the servo. I have all the parts to do 6 wheel steering I just need some free time to knock it out.
Old 05-28-2017, 03:34 PM   #91
thanks for the side shot, right now I think my rear springs are way to firm. I need to soften then up a lot... Do you notice a difference in the way the rear shocks are mounted.. yours are slightly pointing towards each other and mine are both slightly leaning forward..
Old 05-28-2017, 03:52 PM   #92
Boom Racing has the whole xr setup for about 70
Old 05-28-2017, 04:13 PM   #93
snapon boy's Avatar
Yes I saw that my rig performance is very good, scalerfab will be posting a video of it soon.
Old 06-04-2017, 10:03 PM   #94
snapon boy's Avatar
I've been customizing the truck bed.
Old 08-22-2017, 05:03 PM   #95
Any updates on this rig? You cant be finished with it yet lol!
Old 08-22-2017, 05:43 PM   #96
snapon boy's Avatar
I added a crate to the rear for the blu tooth speaker and am looking at getting a brood motor for it my Holmes one is getting tired it's starting to get hot.
149 r/c worx/scalerfab/team brood.
Old 08-22-2017, 06:20 PM   #97
What holmes motor are you running?
Old 08-22-2017, 06:53 PM   #98
snapon boy's Avatar
Holmes hobbies 13t trial Master sensored brushless it's very old was a tester motor for one of hh team drivers years ago.
Old 08-22-2017, 09:21 PM   #99
ok, I am running a holmes TM expert 35t... works well...one day I may go brushless but not sure.
Old 08-22-2017, 10:03 PM   #100
snapon boy's Avatar
I have the ble pro ecs's so I guess I could go brushed but I'll like to pull the kids wagon sometimes
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
