Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Szczerba's 3rd CXT, Build #57
Old 08-30-2016, 11:23 AM   #21
Default Re: Szczerba's 3rd CXT, Build #57
Originally Posted by CM9000 View Post
there goes 2,000 out of my wallet
the trimmed fenders with flaps look good. if I could photoshop the flaps out.. Idk I like the trimmed look better.
pssssst... is bowhouse/ helios doing pass through bolt on 3rd members?
Yup, ill be trimming these fenders for looks and tire clearencing.
Yes, they still have them but are waiting on some fitment testing with new parts to put them back up for sale.
Szczerba is offline   Reply With Quote
Old 08-30-2016, 11:28 AM   #22
Looking good so far, Shane. Can't wait to see more!
And to the questions about the prototypes, you'll just have to see what Shane has up his sleeve.
new2rocks is offline   Reply With Quote
Old 08-31-2016, 07:54 PM   #23
your builds are awesome I cant wait to see the rest of this one
ribaja is offline   Reply With Quote
Old 08-31-2016, 08:13 PM   #24
New parts will be here tomorrow afternoon!
Thanks, I just found some new inspiration on the bumper/bed/metal work for this rig. I have a good direction now and should get cranking on this build fast. I hope, about 6 other projects going on now as well.
Old 08-31-2016, 10:30 PM   #25
Shock mounts, subframe mocked up, MIP cut and shorterened and yadda, yadda, yadda
Old 09-01-2016, 09:20 AM   #26
~THE SCALE SHOP~
would be cool to do some kind of custom grill on this one. to make it different.
STANG KILLA SS is offline   Reply With Quote
Old 09-01-2016, 08:35 PM   #27
Default Szczerba's 3rd CXT, Build #57
I've got metal tube work plans, just trying to find a bender that wont crease 3/8" tube and get a tight bend. Going on a search mission tomorrow.
In other news..
I got in the custom wheels today too. Mmmmm, so cool looking.
Old 09-01-2016, 09:52 PM   #28
Find a coil spring that is slightly larger than the tube you're trying to bend, slide it over where you want the bend, and it'll support the metal and keep it from creasing when you make the bend. Use to be able to find a set specifically made for brake tubing at the local auto parts store.
Mike Flea is offline   Reply With Quote
Old 09-01-2016, 10:31 PM   #29
Moderator Rule Breaker
eric113's Avatar
In other news..
That bender is really made for solid rod. Try searching for a hand held bender that goes up 3/8".
eric113 is offline   Reply With Quote
Old 09-02-2016, 07:21 AM   #30
~THE SCALE SHOP~
X2 my hand tube bender goes up to 3/8" i believe, doesn't mash 3/16 or 1/4" tube. never tried 3/8 though
Old 09-02-2016, 10:38 AM   #31
Hmm, never heard of that. My bender shown does good up to 1/4" or so.
Yah, I know, works good on smaller tubes.
I just picked up a hand bender that goes up to 3/8". It's going to questionable if it will stay together to bend this 3/8", 0.035" wall tube, May have to introduce some heat.
Old 09-02-2016, 03:18 PM   #32
Shane I have a blue point bender that does 3/8 at pretty tight radius ....
viper6171 is offline   Reply With Quote
Old 09-02-2016, 07:29 PM   #33
In other news..
I've been wanting to build my own tube bender for a while now. CODYBOY posted up in the tools thread HEREwith this idea (his links broke or somethin):
Here's the photobucket link:
IMG_6285_2.jpg Photo by ledspots | Photobucket
It seems like a good idea. Radius's may not get as tight but at least they won't flatten. The idea is to tighten the screw/washer onto the tube so it can't expand/flatten during the bend.
dirk379 is offline   Reply With Quote
Old 09-02-2016, 10:51 PM   #34
Thanks guys, I picked up an $8 harbor freight bender today.
Bends 3/8", 0.035" wall DOM pretty easy with minimal inside flattening. I did bend the bottom handle as this 0.035 wall 3/8 is probably it's max.
Whipped this front bumper up
Tacked
Old 09-03-2016, 12:46 PM   #35
~THE SCALE SHOP~
#doyouevenliftbro
Old 09-03-2016, 01:43 PM   #36
#doyouevenliftbro
I was wearing safety glasses and gloves. Bending that 3/8 was super sketchy on that bender but I got done what I needed too.
Old 09-03-2016, 07:05 PM   #37
I am thinking that somewhere I read you could fill a pipe with sand or similar and bend in you garage for 1:1 bumpers and get a smooth mandrel like bend with little to no kinking, not sure how this would apply in scale though. Food for thought!
sled is offline   Reply With Quote
Old 09-03-2016, 07:24 PM   #38
Someone at work had mentioned that to me as well. Luckily, this $8 bender did what I needed it to. Got the rear cab bar bent up last night too and the other stuff ill be bending is smaller and can be done on my other bender.
Old 09-04-2016, 07:55 AM   #39
Beefy
XSRCdesign is offline   Reply With Quote
Old 09-04-2016, 11:42 AM   #40
Originally Posted by XSRCdesign View Post
Beefy
Yes sir. Will me a mix of 3/8 and 1/4 tube.
Wanted to do a different front bumper than the last two CXT's i've built and found a cool 1:1 to borrow some ideas from.
Szczerba's 3rd CXT, Build #57 - Similar Threads
Szczerba's Second CXT Build Szczerba 2.2 Scale Rigs 253 03-08-2019 07:49 AM
Szczerba's 2.2 CXT Szczerba Axial Wraith 109 12-04-2013 06:08 PM
Szczerba's Terra-X Build Szczerba Axial Wraith 21 02-25-2013 09:10 AM
Was Szczerba's Defender 90 Build. On to the Next. Szczerba 1.9 Scale Rigs 22 07-07-2012 05:18 PM
