Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Szczerba's 3rd CXT, Build #57
Old 09-04-2016, 05:17 PM   #41
Default Re: Szczerba's 3rd CXT, Build #57
It's suits it. I likely
XSRCdesign is offline   Reply With Quote
Old 09-04-2016, 05:31 PM   #42
Anyone guess what I got going on here?
Szczerba is offline   Reply With Quote
Old 09-05-2016, 05:07 PM   #43
No guesses? Cool. I'll check back later, until then, No More Pictures for You!
Old 09-05-2016, 05:38 PM   #44
Must be a 3-wheeler. A CXT trike. Well done, sir!
new2rocks is offline   Reply With Quote
Old 09-05-2016, 05:39 PM   #45
Looks like your doing a tag axle
ribaja is offline   Reply With Quote
Old 09-05-2016, 07:01 PM   #46
Bogie axle
Mike Flea is offline   Reply With Quote
Old 09-05-2016, 07:46 PM   #47
Default Szczerba's 3rd CXT, Build #57
Originally Posted by Mike Flea View Post
Bogie axle
Will be functional.
Testing out prototype BowHouse RC #nc60xr axles. A lot of thought into these axle housings. These are the metal infused print from shapeways. XR wide width. Pass through for the 6x6 setup too. Integrated bearing caps on diff cover, 8x13 pinion bearings, splined ends..
Crawler Innovations 6.0 Dueces Wild foams. Part Number 3002.
Old 09-05-2016, 08:06 PM   #48
You sir are crazy lol. I just put my kidney up for sale so I can buy it from you.
Old 09-06-2016, 05:16 AM   #49
[QUOTE=Szczerba;5557886] I've got metal tube work plans, just trying to find a bender that wont crease 3/8" tube and get a tight bend. Going on a search mission tomorrow. [QUOTE]
weld one end shut. fill rod with sand. weld other end shut. and bend
nice pass through btw.
CM9000 is offline   Reply With Quote
Old 09-06-2016, 08:22 AM   #50
[QUOTE=CM9000;5559392][QUOTE=Szczerba;5557886] I've got metal tube work plans, just trying to find a bender that wont crease 3/8" tube and get a tight bend. Going on a search mission tomorrow.
I had heard about that but was too lazy to try it, so I drove 2 hours, round trip, to buy an $8 bender.
Old 09-06-2016, 08:24 AM   #51
Super rough mock up of the 4-link walking beam contraption thingy.
Still work to be done and things to change, so just hold tight, it aint all sorted out.
Old 09-06-2016, 08:28 AM   #52
Shock mounts changed up a bit and sitting on tires
Old 09-06-2016, 09:13 AM   #53
wow that thing is huge! makes the motor look small lol. im wondering how well that rear setup is gonna work... I might be building a m1075..
Old 09-06-2016, 09:21 AM   #54
Should work fine, once I externally and internally limit the shocks. I'll be redoing the suspension link chassis mounting points to move it closer to the axle setup. Suspension link lengths are too long and I am getting some side to side movement but I think with some shorter links, it will be fine.
Old 09-06-2016, 01:47 PM   #55
Woa... That's very cool.
My brain fizzled for a bit while I tried to figure it out. Now it get it though.
Old 09-06-2016, 01:50 PM   #56
1/2" Tube with axle mounts/truss
3/8" tube acts as the pivot shaft. Axle comes all the way out. Need to make "keeper" plates to hold it in place on ends.
1/2" tube mounts on beams.
Old 09-06-2016, 03:42 PM   #57
That suspension is awesome. Inspired me to watch some videos online to learn more about walking beams. Well done, sir.
Old 09-06-2016, 04:31 PM   #58
Realllly interested in those metal printed axles, as far as quality/fitment goes. Without being nosy, was the pricing somewhat reasonable?
BigSki is offline   Reply With Quote
Old 09-07-2016, 10:13 AM   #59
Setup is now a 5-link. Added a panhard bar to the mix that does not mess with suspension movement. Pictures after I finish welding and prime everything.
Old 09-07-2016, 12:44 PM   #60
The axles are very similar to the SCX-width NC60s that are currently available through the BowHouse Shapeways store. Pricing will be slightly higher than the SCX-width version due to slightly larger size. We'll announce everything in a few weeks. And thanks to Shane for being the Guinea pig!
Szczerba's 3rd CXT, Build #57 - Similar Threads
Szczerba's Second CXT Build Szczerba 2.2 Scale Rigs 253 03-08-2019 07:49 AM
Szczerba's 2.2 CXT Szczerba Axial Wraith 109 12-04-2013 06:08 PM
Szczerba's Terra-X Build Szczerba Axial Wraith 21 02-25-2013 09:10 AM
Was Szczerba's Defender 90 Build. On to the Next. Szczerba 1.9 Scale Rigs 22 07-07-2012 05:18 PM
