Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Szczerba's 3rd CXT, Build #57
Old 05-23-2017, 04:20 PM   #161
Proud DMG Stiffy Owner!
allanon1965's Avatar
Default Re: Szczerba's 3rd CXT, Build #57
Originally Posted by Szczerba View Post
Thanks. Everyone asks how many motors I have in it and the bigger 6 door tow rig. Both are running single motors. 1200kv Tekin Roc412's on 4s with a Holmes BLE Pro ESC and correct gearing. Good stuff!
Why does everyone automatically assume that a rig of this size needs more than one motor??? lol!!!
allanon1965 is online now   Reply With Quote
Old 05-24-2017, 08:30 PM   #162
Alot of folks are mis-informed about motor kv, gearing, torque and voltage.
Simple trademark of Holmes sums it up. "Gear down, volt up!"™
Szczerba is online now   Reply With Quote
Old 01-04-2018, 03:27 PM   #163
Default Szczerba's 3rd CXT, Build #57
Still holding up great with the rear printed axles.
Some of the first VP VXDs universals with VXD locker up front working fine on the 21lbs truck.
VP V2 AR60 AL axle housing.
Old 01-04-2018, 03:45 PM   #164
Random clips thrown together. 1080p it.
https://www.youtube.com/watch?v=DKVhG6c44z0
Old 01-06-2018, 02:28 PM   #165
JConcept Ranger tires, custom CAD and printed wheels. CI foams
Old 01-06-2018, 06:02 PM   #166
Didnt get to drive er today but got another picture of the new wheel and tire setup. #szczerbabuilt #CXT
Old 01-06-2018, 08:56 PM   #167
calcagno45's Avatar
Great new look there. Almost like floatation tires.
calcagno45 is offline   Reply With Quote
Old 01-07-2018, 05:54 PM   #168
Yah, I like them for a second set of tires. Waiting on some snow here!
Debating the foam setup but I think Ill leave the rears stock and add a little more foam up front.
Old 01-12-2018, 10:48 PM   #169
Oppan Gangnam Style
chino63's Avatar
I love it! Those tires look great on that rig. How's the grip with those things? Hard as Imex Claw Dawgs in winter or softer and somewhat grippy closer to more modern compounds.
chino63 is offline   Reply With Quote
Old 01-13-2018, 10:36 AM   #170
I got the gold compound which I believe is the firmer of the two offered. Its a firm-ish compound but the tire still really conforms well due to the large spans of material. If that makes sense. Ie wide contact patch and tall sidewalls. I like them.
Old 02-26-2018, 03:21 PM   #171
I was thinking of using those tires on my smt with some crushlock wheels for trailing how would you consider the tires for that? I’d go with the blue compound so softer then what you have now.
snowman13 is offline   Reply With Quote
Old 02-26-2018, 05:09 PM   #172
Cool. Yah, as you stated, I have the firmer compound, just due to the weight of this truck. I have not glued the tires to the wheels just yet, as I am thinking the stock foams just may hold this truck up.
For trailing, I am not sure about this tire, especially on a lighter rig, unless you ran a super soft foam that let the tire conform. Just not alot of tread for grabbing rocks. They didn't like the snow and slipped around on any sort of climb.
Old 03-26-2018, 08:56 AM   #173
A few TTC pictures from this weekend. Didnt have a winch, so that hurt me a few times. Big truck on 1/10 courses but it did ok.
Szczerba's 3rd CXT, Build #57 - Similar Threads
Szczerba's Second CXT Build Szczerba 2.2 Scale Rigs 253 03-08-2019 07:49 AM
Szczerba's 2.2 CXT Szczerba Axial Wraith 109 12-04-2013 06:08 PM
Szczerba's Terra-X Build Szczerba Axial Wraith 21 02-25-2013 09:10 AM
Was Szczerba's Defender 90 Build. On to the Next. Szczerba 1.9 Scale Rigs 22 07-07-2012 05:18 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
