11-23-2016, 05:21 AM | #1 |
Quarry Creeper Join Date: Jun 2005 Location: NW Ohio
| How about a cabover 6x6 hauler
This is supposed to be my winter project but I'm having a hard time leaving it alone. Let's start with a bunch of Axial parts. I scored a couple axles with some Vanquish aluminum goodness. And an extra with aluminum no name lockouts. I used two frames for the rear extensions. I'm making this longer than most scx 6x6's because it is going to haul my trail yota. For now stock trepador tires and wheels will do. |
11-23-2016, 05:53 AM | #2 |
| Re: How about a cabover 6x6 hauler
Made up links with 3mm all thread and thick wall aluminum tubing. For mock up I used offset ball ends until the Traxxas parts came in. And all mounted up. I wanted to keep everything below the chassis line on the rear to keep the bed as low as possible. Mounting the shocks directly on the frame would let me do this. So needing something in the 70mm range I dug through my parts box and came up with four TLT gold shocks and two rc4wd gelande shocks. Removed the springs to run a droop suspension, the soft Trepadors will soak up the bounce for its intended purpose. Yeah mandatory flex shots right?! Not too bad at all. |
11-23-2016, 09:43 AM | #3 |
Went with a 35t motor coupled to a 10 tooth pinion. No speed records here. A Hitech waterproof hi torque steering servo. For now a Tekin FXR speed controller cause I had it. I'll control it with my hacked Flysky gt3b and a 6 channel rx. Driveshafts are rc4wd Punisher front and Devil RC for middle and rear. Now we have an operational big rig. Out on my scale course it handled everything with ease. |
11-24-2016, 12:04 AM | #4 |
Rock Stacker Join Date: Feb 2015 Location: Netherlands
Can i ask you what length links and driveshaft you have used for the rear axle? Thanks great build so far |
11-24-2016, 09:47 AM | #5 |
| Re: How about a cabover 6x6 hauler |
11-24-2016, 09:54 AM | #6 |
How about a little Thanksgiving teaser shot. |
11-24-2016, 04:12 PM | #7 |
Styrene cab back. And aluminum brackets for a tilt cab. |
11-24-2016, 05:04 PM | #8 |
Love it! |
11-24-2016, 08:59 PM | #9 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Very nice work so far! Keep it up 149 r/c worx's Team Driver |
11-25-2016, 12:04 AM | #10 |
11-27-2016, 06:00 PM | #11 |
Got the flatbed built. Aluminum C channel all bolted together. Angle brackets bolted to the frame holes and tie it all together. Used pine wood trim strips for decking. With boards stained and lightly polished the aluminum. I made a rear bumper with angled ends. Will put lights in this. Searched 1:1 trailers to get an idea of ramp brackets. Came up with sandwiching an angle bracket between main frame and bumper. Bed bolted back down and ramps fitted up. |
11-27-2016, 06:19 PM | #12 |
Looks like a good idea.. Excellent 149 r/c worx's Team Driver |
11-28-2016, 11:07 AM | #13 |
Rock Crawler Join Date: May 2013 Location: Uniontown
Nice bed! Sent from my XT1585 using Tapatalk |
11-29-2016, 02:07 PM | #14 |
Looking good. It's builds like this that make me want to build myself another rig. |
11-29-2016, 03:56 PM | #15 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Nice job! Might I suggest under the bed storage for those ramps? Would be cool to slide them in from the back somehow. |
11-29-2016, 05:11 PM | #16 |
Cool ass build. Looks good with the global cab.
11-30-2016, 07:31 PM | #17 |
11-30-2016, 07:36 PM | #18 |
Here's the ramps in action. And the reason I'm building this in the first place. Did a little body work today and sprayed some stuff on the cab. Oh and built something shiny for the front. Stay tuned...... |
12-02-2016, 01:15 PM | #19 |
So I spot puttied the styrene back and tried to sand out some mold lines. Put two coats of primer on then shot some flat black to see what more sanding is needed. It will stay like this while deciding on color and gathering up the rest of the body parts. And I made up a front bumper out of some aluminum flat bar. It bolts onto the tilt frame brackets. So here's the way it sits. It drives and functions. I'll be working on small details from here on out. Will probably be asking for opinions/suggestions. |
12-02-2016, 01:47 PM | #20 |
Newbie Join Date: Jun 2010 Location: Everett
Beautiful!! You gonna put some chrome fenders or something on the cab? Sent from my iPhone using Tapatalk |
How about a cabover 6x6 hauler - Similar Threads | ||||
6x6 Tamiya Knight Hauler? | alexchen86 | Multi Axle Rigs | 3 | 10-13-2015 12:43 PM |
JRP RC - The King Hauler 6X6 | Juddp | Scale Videos! | 2 | 12-18-2013 01:25 PM |
JRP RC - The King Hauler 6X6 | Juddp | Scale Videos! | 0 | 12-15-2013 09:11 AM |
bmuzz1's 6x6 Flatbed Mini Hauler | bmuzz1 | Multi Axle Rigs | 56 | 03-21-2010 09:36 PM |
