02-09-2017, 02:48 PM | #21 |
Quarry Creeper Join Date: Dec 2012 Location: ontario
| Re: WesleyRoy's Black Ops 6x6 truck
That's A Mean Looking Rig !
02-09-2017, 03:21 PM | #22 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
What a transformation for a toyish looking truck to a bad ass Mad Max.... Doing a great job..... |
02-11-2017, 02:45 PM | #23 |
Rock Crawler Join Date: Oct 2013 Location: The Netherlands
| Re: WesleyRoy's Black Ops 6x6 truck |
02-11-2017, 05:57 PM | #24 |
I wanna be Dave Join Date: May 2010 Location: The east coast
I've been looking into the SD I driveshafts myself. Do you have a measurement on what is the shortest length they could be made? I was thinking if I cut the shaft down to the point the two end hit (still allowing them to extend). I don't know how long the universals on each end are. Quote: |
02-11-2017, 09:16 PM | #25 |
For this build i went with Xtra Speed 1/14 shafts. THey are much cheaper then the SDI shafts and look more scale to me. Xtra Speed Steel High Tolerance Driveshaft 62-75mm Tractor Trucks RC #XS-59630 | eBay You can cut them up a bit further. I cut them up to 58mm . They also have washers included, for the small gap between pinion shaft and drive shaft. |
02-11-2017, 09:24 PM | #26 |
The female shaft part is open on the inside, so no blockade in the shaft, the male shafts slides thru, so you can cut them up relatively short. Do you know what shortest distance you want for your build? I think most of the 6x6 have a gap between 2nd and 3rd axle , around 60mm or more. I have used not very big tires 100mm diameter. If you go for bigger tires, the distance between 2nd row of wheels and 3rd could be to small. Maybe i go for 114mm tires in the future, but it will be close then. |
02-13-2017, 01:59 AM | #27 |
Quarry Creeper Join Date: Sep 2010 Location: appleton
I am running 2.2 Mud Slinger XL's on my 6x6. I'm not quite sure of the exact distance but I am using a Junfac shaft that is the correct length for a stock Wraith. Sent from my LG-H900 using Tapatalk |
02-15-2017, 09:47 AM | #28 |
I like the way spare tires are mounted on military trucks. Tried to make something like that with aluminium parts. I didnt want to drill extra holes in the nice frame rails, so after some thinking, found out i could use the holes for the shock mounts. Whole thing is mounted with two screws on the frame rails. Tyre sits snug between the aluminium profile. But is also secured by some chain and tierips. Last edited by WesleyRoy; 02-15-2017 at 09:50 AM. |
02-19-2017, 10:42 AM | #29 |
First real testdrive today. Unfortunately it ended sooner as expected, due to some electronic problems. Well at least i got some photos in the dirt. After a few minutes, my servo stalled and it just locked. https://www.youtube.com/watch?v=lDRrwUxg4PY Then i tried to restart and my esc didnt want to start up (Holmes esc). Could this be solved with a bec. I have a towerhobbies 20kg servo in it. Driving on 2s. WIth a cheap GOOLRC 35t brushed motor. This ESC was working with no problems in my other truck. https://www.youtube.com/watch?v=1pcS0kQyPo4 |
02-19-2017, 01:43 PM | #30 |
03-01-2017, 12:42 PM | #31 |
03-01-2017, 08:32 PM | #32 |
What a transformation! nice work I liked it in the flat green, but love it in the flat black. The details with the spare tire carrier and the accessories make it stand out. What is your plan for the rear, 5th wheel or bed?
03-01-2017, 10:20 PM | #33 |
Pebble Pounder Join Date: Nov 2016 Location: USA
Just cool. It has a primitive ruggedness you'd expect to see in fury road or something similar.
03-03-2017, 12:56 PM | #34 |
Thanks. Thinking about a tow . I tried a flatbed but didnt like it mounted so high on the shock towers.
03-04-2017, 04:09 PM | #35 |
03-05-2017, 05:42 AM | #36 |
03-05-2017, 06:47 AM | #37 |
Rock Stacker Join Date: Feb 2015 Location: Netherlands
That looks better Wes Sjon |
03-06-2017, 04:54 AM | #38 |
Thanks sjon.
03-06-2017, 12:43 PM | #39 |
03-12-2017, 01:52 PM | #40 |
Side by side with my other 6x6. Found out my black ops truck made a lot of noise compared to my other 6x6. At first it looked like my slipper was loose. But after fastened it, i found out it was still loud and skipping teeth. However when i took it al out, the gearbox doesnt had some damage. After a while i found out the cheap Yeah Racing pinion, just didnt line up nice with the spur. Like it wasnt 48p exactly. Went for a Duratrax 32p 56t spur and a 14t pinion and problem is solved, so much more quiet. Happy, because i tought about the worse case scenario, stripped bevel gears etc.. No theres only one problem left, 3 of the 6 shocks are leaking, contacted RC Mart and they will contact the manufacter. In the meantime i orderd some cheap shocks, read some good reviews about them. Anyone running these? |
WesleyRoy's Mad Max inspired 6x6 wrecker - Similar Threads | ||||
WesleyRoy's SCX10 another 6x6 bullhead build | WesleyRoy | Multi Axle Rigs | 47 | 03-16-2018 01:41 PM |
Anyone her play black ops 2? | 98sahara | Chit Chat | 0 | 12-26-2012 03:41 PM |
Black Ops | Harvo | Videos! | 20 | 08-30-2012 04:27 AM |
