Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: allanon1965 builds a 6x6
Old 07-13-2017, 02:31 AM   #81
snapon boy's Avatar
Default Re: allanon1965 builds a 6x6
It will. I have mine running again ill do live test tomorrow and see
Sent from my SAMSUNG-SM-G935A using Tapatalk
snapon boy is offline   Reply With Quote
Old 07-13-2017, 11:01 PM   #82
I mocked up a bumper out of stuff I had laying around. Going to the crawler site tomorrow and will see how it does..I think it is too thick, by just a bit.. the width seems ok and it seems a bit too tall as well.. but it will be a good test for clearance on the rocks and such
allanon1965 is offline   Reply With Quote
Old 07-13-2017, 11:05 PM   #83
Truck is looking good.
Ballistic17 is offline   Reply With Quote
Old 07-13-2017, 11:09 PM   #84
thanks, I will post more pics from the crawler course tomorrow!
Old 07-14-2017, 03:55 PM   #85
got out on the course today, they are in the middle of re-working it so it wasnt as nice as it used to be... the 6x6 did very well, I was pleased with the performance of the truck today. I may eventually see about a different tire, but for now its ok.
Old 07-14-2017, 04:00 PM   #86
snapon boy's Avatar
Freaking awesome
Old 07-15-2017, 08:06 AM   #87
Gonna see about making a better bumper for the front this week.
Old 07-17-2017, 01:17 PM   #88
well, my narrow XR mod beef tubes came in as well as the XR universals... everything went great until I had to shorten the axles, Amain had them already done but they were out of stock so I got the regular ones. I took off too much metal and now they are loose in the locker, but will still work until I get a different set and do a better job or Amain gets the shortened ones back in stock.
Old 07-17-2017, 01:22 PM   #89
Looks good. You could also use the lockers that have the set screws to take us the slack.
Sent from my SM-G920T using Tapatalk
Di_Spencer is offline   Reply With Quote
Old 07-17-2017, 01:24 PM   #90
I have had those before and the set screws always seem to back out even with lock-tite...
Old 07-17-2017, 04:25 PM   #91
I got the XR narrow mod done, used some bomber knuckles and chubs, I fixed up my axle botch job with a tack weld and regrind. I know its not the way to do it, but it should hold up fine until I get replacements. The turning radius before the mod was 59 inches, after the mod it is 41 inches. Nice improvement without having to spacer out the rears to match the width, my width did not change.
Old 07-17-2017, 11:42 PM   #92
snapon boy's Avatar
Very cool man. I will test mine when I get back home. This is going to be a favorite of mine.
Old 07-17-2017, 11:58 PM   #93
Thanks! I am looking forward to seeing your results!
Old 07-18-2017, 07:30 AM   #94
I have pretty much decided to swap out the wild peaks for the Iroks...they Iroks have always been a good tire for my area and they still look scale on this rig...at least to me. Now I just have to order six of them plus CI foams..thinking firm for the rears and medium for the front.
Old 08-10-2017, 05:04 PM   #95
calcagno45's Avatar
What diff gear ratios did you run? standard 38/13?
calcagno45 is offline   Reply With Quote
Old 08-10-2017, 05:09 PM   #96
yup, stock gear ratios and stock gears...will upgrade the gears one of these days to the hardened ones...
havent had much time to run any of my rigs lately as work and the new house being built has taken 99% of my time. I hope to remedy that as soon as we are in the new house by building my own crawler course and air strip for some new planes I will be buying
Old 08-10-2017, 05:21 PM   #97
calcagno45's Avatar
Ok. Not much info on the multi axle build threads on the ratios.
I hear you on the house. We've been in for 3 months now and it's still consuming most of my time. It's crazy and doesn't end.
Old 08-14-2017, 03:12 PM   #98
I am going to try an experiment. I am going to install a front stock gear set from the SMT10 monster truck..its an open diff gear set and I think it will make a big difference in turning but wont have too much negative effect on the climbing ability...
Old 08-14-2017, 05:59 PM   #99
Should be an interesting test. I assume you'll put them in the front?
DrewHammer is offline   Reply With Quote
Old 08-14-2017, 06:17 PM   #100
yup, in the front only, still locked in both rears
allanon1965 builds a 6x6 - Similar Threads
looking for prerunner builds. post builds here wcdfmt510 General Scale Talk 19 06-27-2013 10:48 PM
Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** dankycrawler Multi Axle Rigs 37 04-18-2013 03:09 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
