02-08-2018, 10:38 AM | #1 |
Pebble Pounder Join Date: Nov 2005 Location: south jersey
| 6x6 help
I'm thinking about a scx based 6x6 project. My issue is I'd like to steer all three axles. My setup would be the basic pass thru center axle. In a normal front steer setup you flip the rear axle so everything drives the correct direction. My issue is once its flipped how would I steer it? Also, the center would have no mounts for a servo plate. I searched around but found nothing on a 6wd 6ws setup. Any help, constructive criticism or links to builds would be great. Thanks!
02-08-2018, 11:03 AM | #2 | |
Quarry Creeper Join Date: Nov 2015 Location: Walkerton
| Re: 6x6 help Quote:
02-08-2018, 06:31 PM | #3 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| Re: 6x6 help
I'm sure someone could fab up a servo mounting plate for an inverted axle. Another option is chassis mounted servos. I did it on my 6x6: jebster's 6x6 I did keep mine with a 4-link setup vs going to a 3-link with panhard, which is the best setup if you are going with a chassis mounted servo (cms). The 4-link does give some bumpsteer but pretty minimal. |
08-07-2018, 06:41 PM | #4 |
Quarry Creeper Join Date: Sep 2010 Location: appleton
| Re: 6x6 help
I dont know if you ha e figured out your problem or not. You could always run an SSD D60 axle case. By design the axle is flipped. There are holes for a servo plate or you can run CMS Sent from my SM-N950U using Tapatalk |
08-08-2018, 06:11 AM | #5 |
Quarry Creeper Join Date: Sep 2006 Location: watertown
| Re: 6x6 help
It wouldn't solve steering the middle axle, but if you flip the middle axle you should be able to leave the extra one in the back in the original orientation, and therefore set up the steering just as you would the front axle. At least that's what I'm planning on doing.
08-10-2018, 05:55 AM | #6 | |
| Re: 6x6 help Quote:
08-10-2018, 06:38 AM | #7 |
| Re: 6x6 help
Some places make an aftermarket servo plate that should work. It screws to the top two screws on the diff, the ones that hold it together. Sent from my SM-N950U using Tapatalk |
08-10-2018, 06:39 AM | #8 |
| Re: 6x6 help |
08-10-2018, 09:35 AM | #9 | |
| Re: 6x6 help Quote: Last edited by chino; 08-10-2018 at 10:27 AM. | |
08-10-2018, 09:55 AM | #10 |
| Re: 6x6 help
Yes. It doesn't use the posts to mount the plate Sent from my SM-N950U using Tapatalk |
08-10-2018, 10:29 AM | #11 |
| Re: 6x6 help
Cool. Just ordered it. I'll see how it works out.
08-14-2018, 01:13 PM | #12 | |
| Re: 6x6 help Quote: | |
08-14-2018, 01:14 PM | #13 |
| Re: 6x6 help
Awesome Sent from my SM-N950U using Tapatalk |
6x6 help - Similar Threads | ||||
My HG601 6x6 aka The Dubsta 6x6 | W1ck3d0n3 | Multi Axle Rigs | 5 | 12-21-2020 02:17 AM |
Help with first 6x6 | Betts818 | Multi Axle Rigs | 23 | 06-16-2016 10:12 PM |
Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** | dankycrawler | Multi Axle Rigs | 37 | 04-18-2013 02:09 PM |
6x6 | rockoff | Tamiya Clod Buster | 5 | 01-18-2013 04:05 PM |
My new 6x6 | diantae | Multi Axle Rigs | 7 | 06-07-2011 08:45 AM |
