Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Szczerba's 3rd CXT, Build #57
Old 08-20-2016, 08:50 PM   #1
Default Szczerba's 3rd CXT, Build #57
Custom build #57 since 2007.
1" frame rails
3" door hinge and chunky metal for cab flip mount
Szczerba is offline   Reply With Quote
Old 08-20-2016, 09:34 PM   #2
Default Re: Szczerba's 3rd CXT, Build #57
Almighty Malach is offline   Reply With Quote
Old 08-21-2016, 10:04 PM   #3
Thumbs up to you, sir.
Got some subframe plates cut by SMW. Based on my tired and true big rig suspension geometry.
All VP everything front wraith'd axle setup.
Old 08-23-2016, 06:56 AM   #4
Dibs. you should try scorpios on this rig shane.
CM9000 is offline   Reply With Quote
Old 08-23-2016, 08:02 AM   #5
Dibs noted.
Doh! I was wrestling with tire choices with one of my scale advisers this past week. I was bouncing back in forth between the Sem Fronteria's and the Baja Claws. I wanted a chevron look but the Sem's, I think, were just going to be too narrow. I've run the baja's on my last Dakar CXT and they looked and performed good. Looking at the Scorpios, their height at 5.98" would have been too tall. I would have went with the 2.2 Mud Bashers if I could fit that tall of a tire.
Old 08-23-2016, 08:13 AM   #6
the 1.9 is pretty tall too. I think its almost as tall as a panther cougars. really soft tire. no too wide not too narrow.
and I was just looking at rc4wd kryptons.. to short for this build but if you could make 2.2's that would be a nice tire.
Old 08-23-2016, 09:01 AM   #7
Ran the Kyptons on this 6x6 build. They would be awesome in a factory 2.2 but I think making a 1.9 set into 2.2 would be a tad narrow.
Szczerba's MC6 6x6
Old 08-23-2016, 09:20 AM   #8
is it going to be dually on both rear axles?
Old 08-23-2016, 09:35 AM   #9
Not on this build. Just ordered 8 tires for some spares about back.
Old 08-23-2016, 10:53 AM   #10
Keep it coming!
rockrigcustoms is offline   Reply With Quote
Old 08-24-2016, 08:16 PM   #11
Hot Racing transmission dissassembled, loctite'd, regreased and reassembled. Have had good luck with these transmissions over the years.
RC4WD 32p 64t spur from their ax2 trans fits scx trans with minor modifications. Just have to open center hole a tad. Extended front output lets you run the 64t and still clear MIPs.
Mixed Lucas Red N Tacky with Lucas 5k diff fluid. Going to see how this works in axles and trans.
9t pinion, 1200kv Tekin ROC412
Tight fit
Oh and I have some prototype rear axle housings ill be using. 2 weeks out on those.
Old 08-25-2016, 05:31 AM   #12
ooh the secrets. I love secrets.
Old 08-25-2016, 11:18 AM   #13
Prototype?! Say what?! Always fun watching your builds =)
Shinjari is offline   Reply With Quote
Old 08-25-2016, 11:54 AM   #14
Yups, a housing that is currently offered, just not as I will be getting them. Figure a 14-17lbs truck will be a good testing situation .
Also getting some 3d Printed wheels made up by Primo R/C Engineering. Vendor (Josh4x4toyz) here on RCC. Did my F350 wheels.
Old 08-28-2016, 08:16 PM   #15
Start of front bumper. Just some 1" flat bar, bent, cut and welded onto the cab hinge.
Old 08-29-2016, 05:29 AM   #16
its a bit big for your scale garage. is it me or would it look better without the flares?
Old 08-30-2016, 10:01 AM   #17
Or is my garage too small?
Exhibit A.
2nd CXT I built on the left with trimmed fenders and metal fender guards.
1st CXT I built with no trimming and shorter, modified rockbeasts.
I'll be doing some fender trimming on this 3rd build.
Old 08-30-2016, 10:10 AM   #18
Love it. The CI is my favorite IH build yet
Old 08-30-2016, 10:12 AM   #19
Hoping to outdo that build with this 6x6 build.
Old 08-30-2016, 10:54 AM   #20
there goes 2,000 out of my wallet
the trimmed fenders with flaps look good. if I could photoshop the flaps out.. Idk I like the trimmed look better.
pssssst... is bowhouse/ helios doing pass through bolt on 3rd members?
Szczerba's 3rd CXT, Build #57 - Similar Threads
Szczerba's Second CXT Build Szczerba 2.2 Scale Rigs 253 03-08-2019 07:49 AM
Szczerba's 2.2 CXT Szczerba Axial Wraith 109 12-04-2013 06:08 PM
Szczerba's Terra-X Build Szczerba Axial Wraith 21 02-25-2013 09:10 AM
Was Szczerba's Defender 90 Build. On to the Next. Szczerba 1.9 Scale Rigs 22 07-07-2012 05:18 PM
