06-23-2018, 02:40 PM | #21 |
Quarry Creeper Join Date: Jul 2014 Location: Malta
| Re: Homemade 8x8
Of course there were issues. Mainly the leaf springs did not hold up to the test. I am not running a full set of leaf springs but the net time I go out it will have a full self on all 8 wheels. The torque was too much for them to handle... here's what happened: Hopefully this won't happen again! |
06-24-2018, 10:24 AM | #22 |
| Re: Homemade 8x8
Possible consider using this method of mounting tandem leaf springs? |
06-24-2018, 03:00 PM | #23 |
| Re: Homemade 8x8 |
06-25-2018, 05:41 PM | #24 |
| Re: Homemade 8x8
I just had some axle wrap issues with my tiny tire truck and ended up putting a leaf on top of the whole stack of leafs like so the top leaf does nothing for the spring rate it just helps to prevent the top most spring from getting wrapped/S shaped. This worked good with my little truck but with this 8X8 it may be a different story. Or a zip tie or something to tie the leafs together should also help but it will stiffen up the spring rate. |
06-28-2018, 08:23 AM | #25 |
| Re: Homemade 8x8 Thanks for that .. something to think about and try. I have a complete net set of springs on the way and until then will try anything. I was contemplating a link from the top of the axle housing to the chassis somewhere to stop it from wrapping!
06-29-2018, 11:07 AM | #26 |
| Re: Homemade 8x8
Yeah some links would do the trick and its something thats done in 1:1s too.
06-30-2018, 07:33 PM | #27 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| Re: Homemade 8x8
What was the part # for that HR bell crank? I would like to give one of those a try.
07-04-2018, 05:49 AM | #28 | |
| Re: Homemade 8x8 Quote:
and here's a link for you too https://www.ebay.co.uk/itm/Hot-Racin...kAAOSwVNxaIHAy | |
Homemade 8x8 - Similar Threads | ||||
Capo 1582-2 Tatra 817 8x8 and Cross MC8 Man Kat 1 8x8 | Prop Shaft | Multi Axle Rigs | 24 | 06-18-2021 04:31 AM |
What goes around comes around 8x8 | TheManCave | Multi Axle Rigs | 3 | 04-10-2014 02:37 AM |
The 8x8 | TimR | Tamiya Clod Buster | 15 | 01-11-2008 12:15 PM |
8x8 | Shaggy5050 | Chit Chat | 3 | 12-12-2007 05:32 AM |
