Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Like Tree37Likes
Thread: Homemade 8x8
Old 04-21-2018, 07:00 AM   #1
Default Homemade 8x8
Building my first 8x8 .. decided to go with AR60 axles and 2.2 wheels. So far so good. The chassis is looking awesome in my opinion and am starting with the drive train. Will be using an SCX10 transmission case with Robinson Racing gears - which will feed a homemade transfer case to feed each axle individually. The 2 axles closest to the middle of the truck will have the pinion spin in one direction while the end axles will have their pinion spin in the opposite direction, thus eliminating torque twist completely. Below find two links:
Here's a link to my page where you can find pictures showing where I am with the build so far and the second link to a YouTube video showing you how I made my 3 way transfer case. Enjoy
https://joesrccargarage.yolasite.com...d-progress.php
Natedog, Mike Flea and durok like this.
JoeConti is offline   Reply With Quote
Old 04-21-2018, 06:02 PM   #2
Mike Flea's Avatar
Default Re: Homemade 8x8
What body are you planning on using?
Mike Flea is offline   Reply With Quote
Old 04-21-2018, 08:29 PM   #3
josh6575's Avatar
I have been wanting to try counter rotating shafts on a six by. Looks like your going to put it to the real test at both ends. I'll be keeping an eye on this build. Nice work.
Natedog likes this.
josh6575 is offline   Reply With Quote
Old 04-22-2018, 12:43 PM   #4
Originally Posted by JoeConti View Post
Thank you .. Still at the very early stages of the build. I have 3 of the 4 axles on the chassis - waiting for the u-bolts for the last axle, because , yep, I'm putting this on leaf springs. Here's a link where all the pics are so far:
I like the fact it isn't SCX 10 based and is on leafs. Should be a cool build, and I want to see how the counter-rotation drive line works out.
Sent from my HTC Desire 626 using Tapatalk
Natedog likes this.
tcanin00 is offline   Reply With Quote
Old 04-22-2018, 01:37 PM   #5
Incidentally today I connected the front two axles to the transfer case and pushed the chassis along the work bench - all wheels turned forward and it was kinda strange seeing the shafts turning opposite one another, but worked well so far even though it only moved about 8 inches
There's new pictures at the very bottom of this page at this link
Natedog, tcanin00 and durok like this.
Old 04-22-2018, 02:26 PM   #6
Always building!
jebster's Avatar
Nice setup. I like the transfer case design and how you are driving the axles separately.
jebster is offline   Reply With Quote
Old 04-23-2018, 12:52 AM   #7
I figured that in a real life scenario I would have wanted my truck to be the same - I would not want my ending the trail to depend on one drive shaft driving both axles and depending on that setup in the middle of nowhere, plus they spin in the opposite direction cancelling out all torque twist - imagine a pull-pal event with that ;)
josh6575 likes this.
Old 05-08-2018, 06:17 PM   #8
HumboldtEF's Avatar
Very cool build! Thanks for sharing.
I see 2 motors now
HumboldtEF is online now   Reply With Quote
Old 05-09-2018, 02:53 PM   #9
Extremely informative video! I really appreciate the depth of coverage and the explanations of the engineering.
Rock Dodger is offline   Reply With Quote
Old 05-11-2018, 03:43 PM   #10
I see 2 motors now
Thanks Yes I suspect I will need the extra torque to get this thing rolling over the rocks
Natedog and HumboldtEF like this.
Old 05-11-2018, 03:43 PM   #11
Thank you .. glad you liked and that you did't fall asleep half way haha
Old 05-11-2018, 03:44 PM   #12
Progress so far
Old 05-12-2018, 10:18 AM   #13
Next up is the steering .. I have the front 2 axles working on one servo but I am not happy with the way it performs .. it is not correct and has to many things that can go wrong. Take a look at my video here.
I am looking for a better solution and today I saw a video which showed a better solution and which apparently is more realistic. I will update you all with the progress of the new steering system as soon as I have something to show you
Natedog likes this.
Old 05-12-2018, 01:08 PM   #14
If you want to run 1 servo, I would look into mounting some Bellcranks to one side of the chassis, 1 per axle, then connect the drag links to the bellcranks. Take a look at this one for example. Jebster's 10x10 HEMTT rollback hauler
Natedog likes this.
calcagno45 is offline   Reply With Quote
Old 05-12-2018, 03:59 PM   #15
That is exactly what I was looking at Thank you
Natedog likes this.
Old 05-19-2018, 03:12 PM   #16
While waiting for parts, I decided to give the body a go. Here's what I did so far. This is the way I would like this build to go but then it is all subject to change if need be:
Old 06-21-2018, 07:40 AM   #17
An update:
Replaced the steering system. Old one was not mechanically sound and nor did it make sense, so now I've done some research and gone full on scale - here,s what I used:
Scale steering boxes (you may call them something different)
and here's what they look like installed:
and here:
Natedog and tcanin00 like this.
Old 06-21-2018, 07:42 AM   #18
..... also made this video showing the old and the new steering system plus, the new system functioning
Enjoy
Natedog likes this.
Old 06-23-2018, 03:34 PM   #19
Originally Posted by rcdriftmasterj View Post
Simply incredible! That is a great way to tackle steering. Gives me ideas for my rigs...
Sent from my Moto G (4) using Tapatalk
Glad it was of some help for you
Old 06-23-2018, 03:37 PM   #20
Today I took the truck out for a test run. Drained a 3S 6000mah and gave it my all. it was do or die. I don't want something delicate, I want something robust and that can perform well. Here's what happened:
Homemade 8x8 - Similar Threads
Capo 1582-2 Tatra 817 8x8 and Cross MC8 Man Kat 1 8x8 Prop Shaft Multi Axle Rigs 23 05-11-2015 12:08 PM
What goes around comes around 8x8 TheManCave Multi Axle Rigs 3 04-10-2014 03:37 AM
The 8x8 TimR Tamiya Clod Buster 15 01-11-2008 01:15 PM
8x8 Shaggy5050 Chit Chat 3 12-12-2007 06:32 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
