Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Dodge T-Rex
Old 01-28-2020, 11:22 PM   #1
Zukiiholic's Avatar
Default Dodge T-Rex
Always wanted to build one, One way or another.
Soo.
Poor artist rendition.
Bought the axial frame extension.
Ebay link set. (Lots of options) and rear steer.. Jut because I want something
with rear steer..(using Heyok rear steer with BEC Option)
Did the usual 2 axle flip thingie for center axle and the gears are really crunchy.
Should have bought the stock Axial 6x6 but too deep into it now to go back.
Zukiiholic is offline   Reply With Quote
Old 01-29-2020, 12:12 AM   #2
Zukiiholic's Avatar
Default Re: Dodge T-Rex
Here is where I'm at.
Now what?
Stay tuned.
Old 01-31-2020, 10:48 PM   #3
Zukiiholic's Avatar
I didn't want to destroy a perfectly painted and done body soo...
I used my new spare body and bought another one..
Not sure If I just want to glue the back half under/over the other body or splice and re-enforce some how. (E6000 and Drywall Mesh)
Old 02-02-2020, 10:28 PM   #4
Zukiiholic's Avatar
Took me three times to get this panhard mount built. The rear axle on my 6 x 6 needs to be upside down and backwards
(to rotate in the right direction) and I kept making it on a right side up axle and then the wrong end of the upside down axle. lol
Fabricated on a spare axle.
Old 02-03-2020, 06:45 AM   #5
Very nice!! Good to see some old V1 axles getting put to use.
OSRC is offline   Reply With Quote
Old 02-03-2020, 07:26 AM   #6
Moderator
JatoTheRipper's Avatar
Very cool. I forgot all about the Dodge T-Rex. When I think T-Rex from that era I always think of the reverse trike.
Old 02-03-2020, 10:10 AM   #7
I saw the title and IMMEDIATLY thought of that truck. Great idea!
My only complaint is about the panhard mount. It's FAIRLY low... imo... so it'll have more axle swing than one that sits up off the axle more to give a horizontal link. BUT... i know everyone has their preference, and if it doesn't have a ton of travel, it shouldn't matter.
chevy42083 is offline   Reply With Quote
Old 02-05-2020, 10:32 AM   #8
man this build is cool. i still remember seeing the concept truck at the Big E one year when i went. that was the coolest thing around.
turboturro88 is offline   Reply With Quote
Old 02-05-2020, 03:39 PM   #9
Zukiiholic's Avatar
Thanks,
Very good point about the panhard mount..
The rear does have some issues.
Using the scx10 II shock tower to have upper link mount.
Not working out as good as I thought it would.
Ugh...
Old 02-05-2020, 04:18 PM   #10
Kool idea, I'll be watching this
Mike Flea is offline   Reply With Quote
Old 02-11-2020, 12:26 AM   #11
Zukiiholic's Avatar
I'm working on the PanHard mount but in the mean time,
I received a Chinism center since the Axial flip and thing wasn't working..
I did take the Chinism axle apart to check and add grease. Smooth as butter..
Now to find a rear center drive shaft.
Not enough room for a cut down stocker..
These are just the end caps.
Old 03-02-2020, 09:34 PM   #12
Zukiiholic's Avatar
Taking advice from chevy42083
I redid the panhard mount and installed panhard bar.
Suspension travels up and down with little to no side movements.
Also added the Vanquish pan hard mount. SCX10 IIs placements
just wasn't working out.
Does it matter which top link I remove?
I removed drivers side and seems Ok.
Link tied off to the side for testing.
Old 03-02-2020, 10:41 PM   #13
Zukiiholic's Avatar
I hope there is not too much Torque on the mount.
I couldn't think of a way to add another point of contact.
Yet..
It has a steal ball mount so I can crank down on tightness.
Dodge T-Rex - Similar Threads
Dodge T-Rex 6x6 Project 8695Beaters Losi Micro-Rock Crawler 47 10-21-2012 04:12 PM
