03-10-2022, 04:31 PM | #21 |
Quarry Creeper Join Date: Apr 2013 Location: Oroville
| Re: Jeep NuKizer 6x6 Flatbed
I've got a few updates on this build. I decided to square up and redo the deck on the flatbed. I used a .019 thick aluminum sheet and some popsicle sticks and I used instant coffee and water for the stain. And I was thinking that the side of the bed was lookin a bit naked so I made some side rails. I also threw this in. It's been one of the best sevos I've used and for the price I can't find any better. Sent from my SM-G991U using Tapatalk Last edited by W1ck3d0n3; 04-21-2022 at 07:36 PM. |
03-14-2022, 02:34 AM | #22 |
I made some light buckets for the rear lights but they were a little big so I made a rear bumper to mount them to, I also added some chains to the headache rack. Sent from my SM-G991U using Tapatalk |
03-14-2022, 03:56 AM | #23 |
Quarry Creeper Join Date: Jun 2018 Location: Blaine
I like the new flatbed. Very cool! I might have to build something like that in the future for my TRX6 Sent from my LM-V600 using Tapatalk |
04-21-2022, 06:57 PM | #24 |
| Re: Hg p601 based 6x6 Flatbed
I picked up a rc4wd welder at Amain and I didn't like how they had the welding torch and ground hooked to the welder, so I added my own wires for the torch, ground, and plug, then I used the tube that came with it and hooked it up to a argon tank I made from a toy set I picked up at one of my local Dollar Generals, the made a wood welder rack to mount in the back of the 6x6. Sent from my SM-G991U using Tapatalk Last edited by W1ck3d0n3; 03-01-2023 at 03:30 AM. |
04-21-2022, 10:47 PM | #25 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
Sweet build and sweet little welder!!!
04-23-2022, 12:58 AM | #26 |
This is the toy pack I made the Argon tank from. Sent from my SM-G991U using Tapatalk |
05-07-2022, 01:42 AM | #27 |
I picked up a new body the other day, I'm gittin a bit burned out on the NuKizer body, so I'm goin with a 82 GMC K10 cab, the bed will eventually become a box trailer. I'm goin to do a factory Blue and White paint job on the cab and maybe the bed. The cab and the flatbed will be mounted to the chassis separately so I need to make some body mounts for both. Sent from my SM-G991U using Tapatalk Last edited by W1ck3d0n3; 05-09-2022 at 10:19 PM. |
06-01-2022, 03:12 PM | #28 |
I got the csb mounts welded on the chassis, as well as the bed. I cut and relocated the stack on to the bed and I think they look better there instead of off the side of the cab. For the cab mounts I used, 3/16in (4.76mm) square bar and a some thin sheet metal that I had layin around. The bed mount is 1/2in (12.7mm) square wood dowl held to the bottom of the bed with E6000 epoxy and bolted to the chassis. I ran the bumper supports through the body to help hold the front of the body. Sent from my SM-G991U using Tapatalk |
06-11-2022, 02:20 AM | #29 |
Body is painted, hood is made to open. I used some small hinges for a doll house door for the hood. Sent from my SM-G991U using Tapatalk |
06-14-2022, 04:33 PM | #30 |
| Re: Custom GMC 6x6 Flatbed
I added some 1/4in (6.35mm) lead wire to the front rims to add some weight to the front end because most of the weight is in the back end because of the flatbed. I pounded the lead rod flat so I could do 2 wraps then used a little hot snot (hot glue) to hold the lead then wrapped some electrical tape to secure it. Always wear rubber gloves when working with lead because it can absorb through your skin and possibly give you lead poisoning. Sent from my SM-G991U using Tapatalk |
06-15-2022, 02:03 PM | #31 |
Rock Stacker Join Date: Feb 2012 Location: Charlotte
Sweet Build here! I love the details put in to your rig! |
06-15-2022, 08:57 PM | #32 |
| Re: Custom GMC 6x6 Flatbed |
06-20-2022, 10:56 PM | #33 |
Stock weight and the new weight. Sent from my SM-G991U using Tapatalk |
06-21-2022, 08:50 AM | #34 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
This is great, I really like the use of wood and scale detail on flatbeds. The rig has evolved beautifully. Look forward to more, it’s a fun thread |
06-21-2022, 10:27 AM | #35 | |
| Re: Custom GMC 6x6 Flatbed Quote:
Sent from my SM-G991U using Tapatalk Last edited by W1ck3d0n3; 03-01-2023 at 03:33 AM. | |
07-09-2022, 07:53 PM | #36 |
Big update. I got all the wireing done for the lights ran, I also made a grill and light buckets out of styrene. On the shake down run I noticed that the motor struggled on some obstacles because of the waight of the truck so I swapped in a 55t with a 20 tooth pinion so that should add the Torque that it needs. Sent from my SM-G991U using Tapatalk Last edited by W1ck3d0n3; 03-01-2023 at 03:33 AM. |
11-19-2022, 03:39 PM | #37 |
| Re: HG P601 based 6x6 Flatbed
So I redid the steering mount, also made a Electronics plate, had to redo the steering because of the new steering servo mount, also my front rims we're cutting grooves in my steering arms because of the screws on the inside of the beadlock Ring. So I put the stock hg-p601 rims back on temporarily, but not going to lie it actually looks pretty good with these on there. Sent from my SM-G991U using Tapatalk Last edited by W1ck3d0n3; 11-19-2022 at 08:51 PM. |
12-11-2022, 06:40 PM | #38 |
UPDATE!!! I started on the interior today. Sent from my SM-G991U using Tapatalk |
12-13-2022, 01:36 PM | #39 |
I got Jason Momoa mocked up to be my driver for this rig. Sent from my SM-G991U using Tapatalk |
01-05-2023, 02:59 PM | #40 |
New shoes for the 6x6 Sent from my SM-G991U using Tapatalk |
HG P601 based 6x6 Flatbed - Similar Threads | ||||
Custom 1:10 scale Kahn Defender D110, Jeep Wrangler Unlimited Rubicon, Jeep NuKizer | LandOfTheEagle | Scale Videos! | 0 | 03-14-2020 05:22 AM |
Jeep Nukizer 715 and Jeep Wrangler | LandOfTheEagle | Scale Videos! | 0 | 06-09-2016 07:20 AM |
Jeep NuKizer build??? | 06ToasterBox | Axial SCX-10 | 8 | 01-16-2016 05:28 PM |
Jeep Nukizer (m715) | Silverado1 | 1.9 Scale Rigs | 77 | 10-06-2015 06:13 AM |
