12-28-2020, 01:47 AM | #1 |
Rock Crawler Join Date: Jan 2012 Location: Vitoria-Gasteiz
| Unimog 6x6
Here are some photos of my last purchase, the photos of the ad: It includes axial 2 6x6 combo axe 2300 servo powerpro 20kg 6 beadlock alu metsafil rims 6 tires 1904 gmade 6 x 90mm gmade rsd shocks (4 unopened) 6 PROLINE double compound foam (4 unopened) 2.4 absima cr3p transmitter Untitled by freedom, on Flickr Untitled by freedom, on Flickr Untitled by freedom, on Flickr Untitled by freedom, on Flickr and finally in my house !! Untitled by freedom, on Flickr It's time to update, first remove leads and check axles and tranny, so, new tranny bearings, those of the axles are good and all greased: Untitled by freedom, on Flickr Now the wheels, remove leads, paint rims and change tires: Untitled by freedom, on Flickr Untitled by freedom, on Flickr Untitled by freedom, on Flickr Untitled by freedom, on Flickr After all, it has touched the chassis, repositioning the variator, I have installed a servo winch, I have put raw builders links on the two front axles and some homemade ones on the last axis since those of raw builders were worth none. It has also been necessary to make a panhard bar since I have attached the shock absorbers to the axle, where the lower link goes instead of a little above it as it was originally, so the chassis is a few mm lower and the gap is reduced. I have advanced the turrets of the two rear axles for which the body had to be modified, and less than I thought since I have also added the standard rear bumper of the Vanquish VS4 that fits like a glove, and to put it I also advance the body about mm. and finally I have mounted the 4 shock absorbers that the previous owner gave me disassembled and it already has the 6 equal gmade shock absorbers. Untitled by freedom, on Flickr Untitled by freedom, on Flickr Untitled by freedom, on Flickr Untitled by freedom, on Flickr Untitled by freedom, on Flickr Untitled by freedom, on Flickr Untitled by freedom, on Flickr Untitled by freedom, on Flickr And now the body, remove thousands of stickers that it brought and leave it a little more visible, now just waiting for the Mercedes grill and a bit of brass ... hehehe Untitled by freedom, on Flickr Untitled by freedom, on Flickr Untitled by freedom, on Flickr Last edited by FREEDOM83; 03-24-2021 at 08:18 AM. |
01-04-2021, 06:24 AM | #3 |
| Re: Axial SCX10 II 6x6
Good looking 6x6, really like how those wheels turned out. Those tires have been working out fantastic for me, they probably did great in the snow.
01-07-2021, 01:16 PM | #4 |
Newbie Join Date: Oct 2020 Location: Nowhere
The enhencment looks great, especially the wheels and tires makes it look like a new car! I have two questions, who did u put the parthant bar there? I dont know this axial chassis much but 3 link system holds the axle originally, wasnt enough? will not it hit servo during an action? Did u build the servo winch by urself? Do u control it through transmitter? well.. more questions |
01-07-2021, 11:55 PM | #5 | ||
| Re: Axial SCX10 II 6x6 Quote:
01-18-2021, 12:09 AM | #6 |
yesterday photos WhatsApp Image 2021-01-17 at 11.40.57 by freedom, on Flickr WhatsApp Image 2021-01-17 at 11.40.58 by freedom, on Flickr WhatsApp Image 2021-01-17 at 11.41.01 by freedom, on Flickr WhatsApp Image 2021-01-17 at 13.05.14 by freedom, on Flickr WhatsApp Image 2021-01-17 at 13.05.15 (1) by freedom, on Flickr WhatsApp Image 2021-01-17 at 13.05.16 (1) by freedom, on Flickr WhatsApp Image 2021-01-17 at 13.56.06 by freedom, on Flickr WhatsApp Image 2021-01-17 at 14.00.59 by freedom, on Flickr WhatsApp Image 2021-01-17 at 14.00.59 (1) by freedom, on Flickr |
01-24-2021, 11:42 PM | #7 |
| Re: Axial SCX10 II 6x6 |
02-01-2021, 01:31 AM | #8 |
02-10-2021, 09:06 AM | #9 |
Axial SCX10 II 6x6 - Similar Threads | ||||
Axial scx10 UMG 6X6 problem | shaggybirdman | Newbie General | 2 | 08-19-2020 11:30 PM |
