Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: 3D Printed 1/10 scale big rig build-KENWORTH K100 AERODYNE
Old 01-24-2022, 07:52 AM   #41
Default Re: 3D Printed 1/10 scale big rig build-KENWORTH K100 AERODYNE
At long last, the cab is done....ready to be lowered to the chassis tonight...
orange617 is offline   Reply With Quote
Old 01-24-2022, 09:11 PM   #42
Well, damn...
Looks like the painting skills are way up there too!
Gorgeous!
durok is offline   Reply With Quote
Old 01-24-2022, 09:15 PM   #43
This guy out here showing us all up!
This is turning out to be a beautiful rig. Looks like a professionally made injection molded let.
Nice work! Keep up the amazing work.
Sent from my LM-V600 using Tapatalk
smc-93 is offline   Reply With Quote
Old 01-25-2022, 07:12 AM   #44
@ smc-93 and durok...thank you guys, im just so relieved to finally finish this build coz im already itching to start the next one....but i still need to paint the trailer...and another 4 wheel build....by the way, i only used acrylic paints from michaels/hobby lobby using an airbrush and finish it off with a couple coats of rustoleum gloss clear...stripes are vinyl sheets...and...finally, here she is...
Old 01-25-2022, 09:56 AM   #45
Location: North to Alaska - go north, the rush is on....
Your attention to detail is astonishing!!!
The rig looks amazing!
AK KRAWLER is offline   Reply With Quote
Old 01-25-2022, 10:21 AM   #46
Thank you AK Krawler.
Old 01-25-2022, 08:35 PM   #47
A few group pics for size comparison...
Old 01-25-2022, 11:25 PM   #48
test run...
https://www.youtube.com/watch?v=b2h3LRIF1pc
Old 04-10-2022, 04:09 PM   #49
Originally Posted by orange617 View Post
Got a quick question I’m building a heavy wrecker from the ground up can you point me in the direction as to where you got your axles?
Kessler072290 is offline   Reply With Quote
Old 04-10-2022, 04:40 PM   #50
[IMG]152044927-413551009745037-2559356587609230900-n[/IMG]
[IMG][/IMG]
[IMG]20210322-002955[/IMG] [IMG]20210322-003011[/IMG]
[IMG][/IMG]
[IMG][/IMG]
Hey bud anyway I can pay you to design my wrecker already have the stl files of the wrecker body but it’s no where near your detail level
Old 05-03-2022, 01:58 PM   #51
Hey bro, these are the cheap axles i used on this build, around 34 bucks for a set of front and rear from banggood (13 bucks for the rear axles).... the diffs are locked with double reduction bevel and spur gear combo....and quite tough too....these are the ones i am using on my latest M1070 build also... you can google HG-P402 axles to check for sellers (i prefer bangood though slow in delivery but still arrives in good shape), they come with sleeve bearings so i usually replace them with sealed ball bearings for a smoother roll... ebay also lists a few of these axles though priced a little more...
https://usa.banggood.com/Front-+Rear...r_warehouse=CN...
https://usa.banggood.com/HG-P401-P40...r_warehouse=CN... i prefer these axles as i already have modeled the adapters so i can set it up with a front leaf spring or with a center bogie rear axle assembly.
let me know if you have questions, i can also send you the stl files for the axle adapters including the whole suspension system if you decide to start work on it.
Old 05-03-2022, 03:40 PM   #52
I can't speak for Kessler but I'd be interested in the . STLs for your suspension system.
I have a set of RC4WD Blackwell's for a future build and want to do a tandem rear leaf set-up. The only setups I can find in that configuration are either 1/14 or 1/12 and look a little too small compared to the Blackwell's.
Edit: Disregard that. I took a closer look at you suspension setup and took some measurements of the Blackwell's, I don't think your kit is going to work.
I might have to try designing my own and figure something out for correctly sized leaf springs.
Old 05-05-2022, 02:28 PM   #53
Yes sir, sorry for the delayed reply but the axle adapters were designed to use only the HG-P402 axles as i have said, as well as a 1/2x5/8" aluminum channel i got from Lowes....the HG's are cheap axles so if in the future you want to try it, i will gladly can share the STL files.
Old 05-05-2022, 03:03 PM   #54
I appreciate it.
I do have a set of those axles laying around as well, don't know if I'll end up using them for anything though.
Old 05-10-2022, 05:47 PM   #55
dammmmm!!! that paintjob is killer! And all that detail...
cooper_xl is offline   Reply With Quote
Old 05-17-2022, 11:08 AM   #56
Finally, painting of the flatbed is done....
Old 05-17-2022, 11:08 AM   #57
Thank you sir...appreciate it.
Old 05-17-2022, 11:15 AM   #58
My entry to the company car show open class....lucky me i won first place...yahoooo.
Old 05-17-2022, 09:18 PM   #59
Congratulations, well-deserved, indeed!
It's amazingly realistic with the paint completed!
Old 08-08-2022, 04:27 PM   #60
Wow just seeing this build and I am blown away with it. I was thinking of doing a 6x6 tamiya semi build on here but I can't compete.
Congratulations on the first place.
Druxus is offline   Reply With Quote
3D Printed 1/10 scale big rig build-KENWORTH K100 AERODYNE - Similar Threads
Kenworth K100 skl1cent Non Crawler RC's 12 03-25-2011 09:27 PM
Big Rhonda 3 - Blue's 2010 MSD Scale Nats Trail rig BlueMonster 2.2 Scale Rigs 7 03-24-2010 10:14 PM
big beefy beast or small scale rig? smallblock500 General Crawlers 12 12-24-2009 10:29 AM
Want your rig printed in a mag? JasonInAugusta General Crawlers 56 11-17-2008 01:35 PM
