Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Axial 6x6 Chassis strengthening.
Old 04-07-2021, 10:34 PM   #1
Default Axial 6x6 Chassis strengthening.
Have a project I picked up an Axial UMG 6x6 roller for.
It will need to be beefed up for my use.
What is the best way or methods to strengthen the chassis.
Or would you just buy some quality C-Channel and go that route?
Straight chassis rails wouldn't be a biggy for my purposes.
Just wondering what options others have used.
Timmahh is offline   Reply With Quote
Old 04-07-2021, 10:46 PM   #2
Fricker08's Avatar
Check out Soze’s build in here, he designed a chassis brace for the stock chassis that makes a huge difference
That or go totally crazy and build it in the new gspeed Carbon rails
Fricker08 is offline   Reply With Quote
Old 04-08-2021, 12:39 PM   #3
Default Re: Axial 6x6 Chassis strengthening.
Well, as this won't be a crawler when it's done, I don't think the CF rails will do what I need from them, unless they were C-Channel.
I contemplated a 2nd set of rails and then wire welding them together.
But simple C Channel, even aluminum, would probably work out better.
Just looking at other options.
I'll check out Soze's build.
thanks for the heads up.
Axial 6x6 Chassis strengthening. - Similar Threads
SCX10 strengthening foratm Axial SCX-10 7 01-06-2012 12:55 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
