Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: FREEDOMs Tatra 813 Kolos (Cross-RC BC8)
Old 11-13-2023, 03:46 AM   #1
Default FREEDOMs Tatra 813 Kolos (Cross-RC DC8)
Finally, after years behind, before even releasing Cross-RC, I wanted it since I tried Spintires in 2009, I wanted something like this and I was finally able to buy it:
This is evidenced by the weight of the box: 12.9 kg, light as a feather hahahaha
As you can imagine, I will post photos and more of the assembly, I want to do an unboxing, and if I can I will record the assembly process, at least the mechanics.
FREEDOM83 is offline   Reply With Quote
Old 11-13-2023, 06:25 AM   #2
Default Re: FREEDOMs Tatra 813 Kolos (Cross-RC BC8)
At the moment I have only opened it to get the manual, which I was curious to see because I was not even looking for more than a photo in the German forum, if anyone is curious, write to me and I will send you what you want to know hehehehe.
The size like the truck, big and fat hahahaha, 88 easy steps to complete it:
And if I have seen many corrections in the mechanical part, many, if not all, I knew about again thanks to the German forum, but there are quite a few: :
This afternoon I will take photos of the bags so you can see each and every one.
Old 11-13-2023, 10:49 AM   #3
I like building kits, but I must admit, I threw up a little in my mouth when I saw how thick that instruction book was.
It is nice to see they have taken the time to correct the manual, hopefully all of the corrections are actually there.
Look forward to seeing your progress on this beast!!!!
Greatscott is offline   Reply With Quote
Old 11-14-2023, 01:32 AM   #4
Here I leave some photos of the bags, everything looks very good, and although I have seen better organized kits, I have also seen worse ones, we will see how it goes with the assembly.
Old 11-14-2023, 01:32 AM   #5
The wheels, as I already read in the forum , are difficult to heel, very very tight, and there is plenty of foam, so first, cut the foam a little:
And a little more than two hours later, I managed to assemble 4 of the 8 wheels, hard work, first with long screws almost to the stop and by wetting my lips very well to get the beads on, without wetting, impossible, but hey, here's the fun hehehehe:
Honestly, the assembly is what I like the most, but the truth is that it is very easy to make the wheels bead easier, not because the brands don't do it many times.
Old 11-14-2023, 11:34 AM   #6
It looks like all of the bags and part trees are nicely labeled, are they clearly referenced in the instructions, so you know what bad or tree you should be using?
Old 11-14-2023, 12:07 PM   #7
Yes it is very clear, but depending on what step , and it happens in many steps, you have to take pieces from several bags.
There I loved Vanquish, since each bag contained each step with the hardware of that step, the assembly is much cleaner, more so than with the DC8, you end up with many open bags but not empty still the end
Old 11-16-2023, 01:49 AM   #8
Today I started with the matter, the extra bumper and the axles and some details, I leave you photos:
Here's a ball joint that came half the size hehehe less, which is something we have plenty of
And here is today's work
Old 11-16-2023, 02:41 AM   #9
servos arrived !!
Old 11-16-2023, 05:22 PM   #10
Very nice aquisition...
cooper_xl is offline   Reply With Quote
Old 11-17-2023, 12:59 AM   #11
Thanks mate !!
Old 11-17-2023, 01:00 AM   #12
Well, so far with the servos and the 1200kv fusion, it's 7.4kg, the thing weighs hehehe, everything is very tight, removing a defect in the chassis that I will show later and readjusting the front leaf springs:
Old 11-17-2023, 05:40 AM   #13
What a cool driveline! Looks like an awesome build
OSRC is offline   Reply With Quote
Old 11-17-2023, 06:14 AM   #14
Oh yes , its lovely if you like mechanics , more than bodywork for me
Old 11-17-2023, 05:39 PM   #15
Wow, so many parts! Great build, thanks for sharing!
justinart24 is offline   Reply With Quote
Old 11-17-2023, 11:00 PM   #16
Very cool, Thanks for sharing the build!
I've got a BC8 which is pretty fun to run. It has independent suspension and a giant skid the length of the rig, this must have a bit better ground clearance.
HumboldtEF is offline   Reply With Quote
Old 11-19-2023, 06:50 AM   #17
So envious. Would love to build this over the winter
Old 11-20-2023, 01:24 AM   #18
Thanks !!!
Thanks !!!
I always liked the Maz537, although less than the Tatra and its mechanics, but above all I ruled out the Maz because I don't want to disassemble the entire truck to grease the differentials, it seems crazy and absurd to have to dismantle everything and it is not the mechanical problem, it is It would be necessary to remove the lighting wiring and many things, not just mechanical...
I believe you, the mechanical part lasted less than I expected to be honest, you can tell that I love it, just as you can tell that I hate the paint job hehehehehe
At the moment , its alive !!!
https://youtu.be/gqpHbPt3H7o
Old 11-22-2023, 02:18 AM   #19
Well, a little hour each day, but little by little I'm going with the painting and "aging" it, it's my first time, and I think it doesn't look bad hehehe
For now the wheel covers:
and here the logo, it brings it, in transparent pieces next to the crystals:
Old 11-24-2023, 12:54 AM   #20
Slowly
FREEDOMs Tatra 813 Kolos (Cross-RC BC8) - Similar Threads
Cat's Cross RC DC8 (Tatra 813 Kolos) Arctic Cat ZRT Multi Axle Rigs 7 07-30-2022 01:45 PM
Tatra 813 1:10 I have no idea Multi Axle Rigs 3 01-07-2021 01:24 PM
8X8 Tatra 813 Kolos Dready Multi Axle Rigs 12 03-25-2014 03:34 PM
Tatra 8x8 813 Kolos / nuff said Don-Pero Multi Axle Rigs 9 09-18-2011 08:55 PM
Tatra T813 Kolos MC-Maxim General Scale Talk 6 08-30-2007 01:52 PM
