Go Back   RCCrawler Forums > Regional > Southwest > New Mexico
Thread: Major carnage at white wash!
Old 11-22-2009, 03:46 PM   #1
Default Major carnage at white wash!
I ended up going out to White Wash (off Candelabria) instead of Rock House - although I don't think it would have mattered . . .
I wasn't there 15 minutes when I heard a snap and noticed I now had three wheel drive!
The Drivers front wheel wasn't turning, and I could hear the axle clicking.
I took a quick look, and noticed the drivers side lower axle C was cracked. Well, I ended up going back home - I knew it wasn't something I could fix out on the rocks.
Here is what I found on closer inspection:
I think the stock Tamiya CVD broke, and when it did it broke the lower axle C. The drive pin on the axle is also sheared off.
So If I were to keep the TLT axle and fix what is broken, I'm looking at a set of Fat Rock axle Cs (if I can find them), or Montana Scale Designs axle Cs ($), and a set of CVD axles - either MIPs or RC4WD. Minimum cost would be just over $100 (per axle).
. . . or . . .
Dump the TLT axles and buy two complete AX-10 axles with hardened lockers for $40 each, and crawl on.
. . . That's a no brainer!
I can't get the Fat rock Cs for the TLT anymore, and the ring and pinion and the axle shafts are weak anyway.
The AX-10 axles are a better, newer design. There was nothing left of my TLT except for the axles anyway.
OH WELL!
I had fun anyway (and it DID take me 4 years to finally break the axle).
John "What's my VISA Limit" Rabenius
jrabenius is offline   Reply With Quote
Old 11-22-2009, 06:17 PM   #2
. . . or . . .
OH WELL!
I have all the parts you need to make it whole again. PM me if interested.
Welcome to NM. I am glad to see another rig that was built not bought.
frankenstunk is offline   Reply With Quote
Old 11-22-2009, 07:50 PM   #3
Default HMMM, A trade then . . .
I have a pretty good assortment of AX-10 and TLT parts and pieces. Maybe we could work out a trade.
Call me on my cell at 919-428-5901
John
Old 11-24-2009, 08:43 PM   #4
RAM2500's Avatar
Nothing like a little cold weather wheeling to find the weakest link in your rig!
RAM2500 is offline   Reply With Quote
Old 11-27-2009, 08:52 AM   #5
Default Back in the saddle again
I'M BAAACK!
I finished rebuilding my TLT - I think I'm going to have to re-name it though. I don't have one TLT part left on it.
I fabbed up some tie rods from Axial 98MM lower links together with an 8MM spacer. Should hold until I can order the correct links.
It has a ProLine Defender (SUZUKI SIDEKICK) body, so maybe I should refer to it as the ZUK.
I'll be out at the scale crawl this weekend!
John
