03-21-2010, 06:05 PM | #1 |
Newbie Join Date: Aug 2009 Location: Albuquerque, NM
| yota on thr rocks |
03-21-2010, 07:52 PM | #2 |
Rock Crawler Join Date: Dec 2007 Location: Maple Grove, MN
What cha' getting at? The link no workie. You a big tease... |
03-21-2010, 08:16 PM | #3 |
| youtube slow!!
03-21-2010, 11:06 PM | #4 |
Newbie Join Date: Jul 2005 Location: Albuquerque
| I DUNNO . . . I thought it would be bigger . . . I guess with a lot of practice you can work your way UP to a Land Rover . . . John R |
03-22-2010, 07:13 AM | #5 |
03-22-2010, 09:27 PM | #6 | ||
Rock Crawler Join Date: Nov 2006 Location: Albuquerque
Yoda looks great! | ||
03-23-2010, 08:50 AM | #7 |
| How about a scale run this weekend? I'm willing to risk my shiny orange paint job so see how I do against Yota - White Wash or Rock House (by the ticket stand)? Saturday or Sunday? By the way . . . I haven't seen that BLUE BRONCO in a while. I wonder if it still runs . . . Coon - How about that Land Cruiser - up for a challenge? John R |
03-23-2010, 08:59 AM | #8 | |
03-23-2010, 10:37 AM | #9 |
Newbie Join Date: Dec 2009 Location: In the mid
Do it red neck style. Two four wheel drives on asfault tied together , pull till one breaks or one goes over the line
03-23-2010, 11:20 AM | #10 |
03-23-2010, 11:40 AM | #11 |
hey john, what motor trans combo you running? just so you kknow im not using the holmes motor, i changed my mind. Last edited by Superclass; 03-23-2010 at 01:24 PM. |
03-23-2010, 03:02 PM | #12 |
| The Land Rover has the ARTR transmission with the stock gearing (87 Spur/14 Pinion). I am running the stock ARTR axles with HD (steel) ring and pinions (43/13), HD (steel) lockers, and when they come of backorder, aluminum knuckles and axle C's. I am running TRAXXAS big bore shocks from the T-MAXX (XXL) with 3 hole pistons, 20 wt oil, and Losi white springs. I ordered a set of Losi 4" crawler shocks but, - you guessed it, they are also back ordered. I am running the stock Axial driveshafts (later version). I have the stock Axial Y-link up front with a four link in the rear. . . . and I'm running a Hitec 645MG steering servo (for now) with the Hand Brothers SCX10 steering - only I am not using the HB panhard bar or the 3 link setup. When I get some more money, I will upgrade to the Hobbico CS-170 steering servo. I am running Axial 1.9 8-hole beadlocks with G8 Flat Irons. I think I have 2 to 3 ounces of lead in the rear tires, and 5 or 6 ounces in the front - I'd like to add more, but I would need (heavier) rims. I am running the Integy V11 50 turn motor with different brushes (the stock ones get stuck in the endbell and are crap). The Land Rover runs a 10.75 inch wheel base, and the track width is stock Axial (no spacers). I think with more wheel weight I could equal the performance of my Suzuki - right now, its close. The articulation is very good - I can max out the travel on the shocks before I start to lift a wheel, and it will compress the rear suspension about 1/4 of an inch on steep hill climbs. Balance is very near perfect. I found a scale company in England that makes a set of cut out Bushwacker style flares specifically for my truck - except they are $50 a set. They look to be first rate quality, and are neoprene rubber. They are made to run 2.2's on the New Bright LR3 body. We'll see - hopefully I get the job tomorrow so I can finish it up. John R |
03-23-2010, 03:11 PM | #13 | |
I'm sure you have a good idea what motor you want to try now. Why didn't you like the cobalt puller motor? The Novak 55 is a good motor. So is the Integy V10/V11 motors. For $30 you can't go wrong. Personally, I would rather have a higher turn motor - say 50 or 55 turn, with a higher tooth pinion (like a 13 or 14 tooth for 2.2's, and 14/15 tooth for 1.9's). That way you have the extra torque to spin the larger pinion, rather than using a lower turn motor (less torque, more RPM) trying to generate torque at low RPM. John R. | |
03-23-2010, 07:19 PM | #14 | |
03-23-2010, 07:26 PM | #15 |
Newbie Join Date: Mar 2010 Location: albuquerque
| Hehehe!!!!
Im going to bring your mom to the sled pull!!!! |
03-23-2010, 07:30 PM | #16 |
03-23-2010, 07:41 PM | #17 |
| Good luck with interview john were pullin for ya!
03-23-2010, 07:53 PM | #18 |
03-23-2010, 08:28 PM | #19 |
03-23-2010, 08:32 PM | #20 | |
