Go Back   RCCrawler.com Bulletin Board > Regional > Northeast > New York
Thread: Crawling at wram show
Old 02-16-2009, 11:26 AM   #1
Default Crawling at wram show
HEY GUYS BRUCKNER HOBBIES IS SETTING UP A ROCK CRAWLING WALL AT THE WRAM SHOW AT THE WESTCHESTER COUNTY CENTER IN WHITE PLAINS NEW YORK, ITS OUR FIRST TIME SO PLEASE IF YOU HAVE A CRAWLER BRING IT FOR INFO CALL THE SHOP 718-863-3434
fperez0209 is offline   Reply With Quote
Old 02-16-2009, 11:38 AM   #2
It's too bad that the Clodbuster racing event wasn't needed to run this year. That always drew a huge crowd.
CPE MT is offline   Reply With Quote
Old 02-16-2009, 05:56 PM   #3
kool ill have to get at it and run you all over w/ my scaler
big bronco is offline   Reply With Quote
Old 02-18-2009, 07:04 PM   #4
Default Rock wall lookin' tight!!!
OK GUYS!!! He is not kidding!!! Talk about dedication to the cause. BRUCKNER HOBBIES makin' it happen!!! SEEN IT, AND IT'S PRETTY SICK!!!
bvek is offline   Reply With Quote
Old 04-13-2009, 12:36 AM   #5
I know am a little late with this but when is the "WRAM SHOW"?
Thanks
TDCrawler is offline   Reply With Quote
Old 04-14-2009, 07:29 AM   #6
TD The show was back in Feb. You should come out to Orchard Beach, Sundays around 12:30 - 1:00, once you past the gates to come in go all the way straight to the end and make a left then park anywhere by the corner of the lot. If you don't see anyone in the lot then go to the boardwalkand go left to the end. Once at the end you have to go left on to the shore (this is the rocks!!!).
Old 04-14-2009, 11:35 PM   #7
bvek,
That sounds good I will have to check that out. Do you guys know of any other hobby shows you would recommend going to in the near future.
