is 2.2 txt possible? can the txt axles be set up for 2.2 comp? |
Search this section for 2.2 and you will find a few. The big thing is the width, so you need some negative offset wheels to bring it as narrow as possible. The TXT axles can handle alot more abuse than tlt, so it makes for a pretty much bomb proof 2.2 . |
TCS has VF Assassin Wheels w/ offset for wider axles. If the 2.2 comp setup doesn't work out you could do a 1/6 scale like Slugzracing did in the Large Scale forum. Edit: Run2Jeepin started a 2.2 TXT Here's a pic to give you a idea http://i218.photobucket.com/albums/c...02/22TXT-4.jpg |
http://i113.photobucket.com/albums/n...p/000_1256.jpg i got my txt done under 10 1/2 wide here is a pic |
How? |
Yep! I built one a long time ago. You'll definitely not break a TXT axle with 2.2's! http://pics.montypics.com/csr/2006-0...4_100_0071.jpg |
