| | #1 |
| Quarry Creeper Join Date: May 2007 Location: Rancho Cambodia
| Will a wk spur gear bult up to a scorpian ax10 tranny? Or will i have to buy a different pitched spur for the ax10? |
| Sponsored Links | |
| | #2 |
| . ![]() Join Date: Nov 2005 Location: Rock chucking territory
| | #3 |
| i have a spur on my wk tranny but i have an ax10 on the way and need to know if i need to source a new spur gear for the ax10? |
| | #4 |
| Quarry Creeper Join Date: Nov 2006 Location: Manchester
| I tried my stock WK spur on my axial tranny and from what I remember, the holes were off by a tiny bit. You might be able to enlarge them or drill new ones to make it work. I just bought a new one for a couple of bucks. |
| | #5 |
| Damn-I need a chump RT!!! ![]() Join Date: Sep 2007 Location: Lost as hell.....
| The holes dont line up. |
| | #6 |
| Picky Fab'r/Acetal Junky ![]() Join Date: Jul 2006 Location: Arizona Desert/AJ
| The simple answer: NO, it won't bolt right up. I installed an HPI spur on my AX trans by just nipping off the 3 little nubs on the AX's spur gear hub, and then just drilling three new holes to match the HPI spur. The center bore is the same, so the only issue is with the nubs lining up....so get rid of them Kimbrough spurs are the direct fit to the AX trans. |
| | #7 |
| Quarry Creeper Join Date: Nov 2007 Location: barre
| traxxas spurs will fit also just need to drill the holes a bit but they line up and dont have to remove the pins on the plate it mounts to |
| Thread Tools | |
| Display Modes | |
