| | #1 |
| Pebble Pounder Join Date: Jan 2008 Location: canada
| what if i locked diffs and added 20turn or 15turn moter? good idea bad idea?why? |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jun 2007 Location: Sacramento
| bad idea if you want any hope of crawling well. If you're running all stock components, you'll blow up the ESC with a 15T motor. I'd keep the 27T motor, re gear it to 96/15 and extend the wheel base. Before I got a 55T motor, the stock motor did a pretty good job of keeping me entertained speed wise, but could still crawl moderately well. With this you'll have a truck that is moderate at best for both speed and crawling. Wanting a fast truck that is also a good crawler is like asking for a 747 you can park in your garage, it's just not gunna happen. |
| | #3 |
| Powered by Awesome ![]() Join Date: Sep 2004 Location: Castle Rock, Colorado
| best way... 3 speed tamiya tranny... you can go crazy fast or uber slow!!! |
| | #4 |
| Rock Crawler Join Date: Jul 2007 Location: Rectalville
| I run a Multiplex 18T 550-size motor on mine, and even geared 96/15 it can do a pretty good clip and still crawl fairly well. I'm also running a Moped V16R bravo ESC, the stock ESC gave up the ghost on me. One BIG thing that will make your truck go a LOT faster as it is would be to buy a good NiMh battery. I've got a 3300 Venom pack that I run and it really woke it up. |
| | #5 | |
| I wanna be Dave Join Date: Jan 2006 Location: CA
EDIT: Yes, a better battery ie: NIMH 3000 - 3300mah will really help. The stock battery is pretty weak. | |
| | #6 |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
| Best thing to do is get a Holmes Hobbies Cobalt puller motor (10T or 7T) or a Torquemaster motor. These motors give you the best low speed crawlability with lots of speed. I run a 10T Puller on a 9cell NiMh pack and it will crawl and go fast. http://holmeshobbies.com/home.php?cat=17 Another option is the Revolver Black from Holmes Hobbies, when coupled with a Mamba 25 ESC and running on 11V you get some great speed with the right gearing. The low speed control is not as good as a brushed motor but unless you are doing competitions it is just fine. http://holmeshobbies.com/product.php...&cat=19&page=1 |
| | #7 | |
| | #8 | |
| | #9 |
| Rock Crawler Join Date: Aug 2006 Location: On the trail
| the stock esc get hot even with a 45t or higher motor? |
| | #10 |
| No, not really. I run a 55T Integy motor with stock ESC and a 7 cell battery, and it never gots hot anymore. I even have the rx and esc in a (mostly) sealed plastic box for water resistance (note: NOT water proof!). It used to overheat ALL the time with the stock motor, but the minute I went to the 55T, all my overheating problems went away. |
| | #11 | |
| | #12 |
| the 55T's ARE pretty slow, but it'll never overheat. If you want a compromise, maybe look at a 35T-45T motor. The nice thing is that brushed motors are cheap (~$20) so they're not too expensive to experiment with. If anything, you might consider getting two motors, a low turn (anything lower than the stock 27T and you'll need a new ESC) for speed and a high turn (55T+) for crawling. If you'r running a stock chassis, it should only take a minute or two to change them... |
| Thread Tools | |
| Display Modes | |
