Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Crawler motor break in`s
Old 01-17-2008, 05:15 PM   #1
Default Crawler motor break in`s
I just bought a Integy V10 Rock Crawler Professional Motor 55S and was not sure if a break in is required with Crawler motors, any help would be appreciated.
Thanks
Last edited by dendrobate; 01-17-2008 at 05:27 PM. Reason: why move it here when no thread is in electronics?
dendrobate is offline   Reply With Quote
Old 01-17-2008, 05:55 PM   #2
Mayor of Bedrock
freetimecrawler's Avatar
IMO break in is not necessary for a crawler motor.
I've never broken any in.
freetimecrawler is offline   Reply With Quote
Old 01-17-2008, 07:22 PM   #3
TEAM MODERATOR
Reflection's Avatar
The break in procedure I like to use..... Charge up a 10 cell sub C pack or a 3 cell lipo,plug everything in and stab the throttle wide open.
Reflection is offline   Reply With Quote
Old 01-17-2008, 07:27 PM   #4
Powered by Awesome
TwistedXT's Avatar
i hook up a new motor straight to a 7.2 pack... charge the pack.. let it run till the battery is almost dead.. do it again... and again.. this will form the brushes to the comm giving you a great contact and make the motor run better.
TwistedXT is online now   Reply With Quote
Old 01-18-2008, 01:11 PM   #5
I noticed when I first operated my power setup, novak crawler, integy 55t, that it was really glitchy. after the first couple packs though, the motor broke in and now it doesn't glitch. guess it really depends on you setup...
I would say "yes", break in your motor
mysharona is offline   Reply With Quote
Old 01-19-2008, 05:56 PM   #6
Most crawler motors are cheap lathe motors, so the best thing you can do is turn the comm and cleans up the brushes before you even run it. Now you guys with out lathes are probably out of luck. I even put better brushes in before I run it.
Later,Randy
racerrandy is offline   Reply With Quote
Old 01-19-2008, 08:01 PM   #7
TEAM MODERATOR
Reflection's Avatar
Later,Randy
I ain't out of luck....I just throw the brushes away. Don't need them stupid things anyway
Old 01-19-2008, 09:05 PM   #8
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
I agree with freetimecrawler, getting a full seat on the brushes won't make much if any difference in preformance at the RPM we run our motors at.
Stormin2u is offline   Reply With Quote
Old 01-19-2008, 09:24 PM   #9
hitman46mod's Avatar
IMO not needed.
hitman46mod is offline   Reply With Quote
