Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: AX 10 Drive Shaft Problems
Old 01-17-2008, 07:26 PM   #1
Default AX 10 Drive Shaft Problems
I am having trouble with ax 10 tranny because my shafts keep popping off. HELP!!!!!!!!!!!!!!!!!! (please)
AXIAL CRAWLER is offline   Reply With Quote
Old 01-17-2008, 07:37 PM   #2
Welcome to the club!! Myself and about every other AX10 owner have experienced the same problem.
I'd say the best fix is to get a new set of drive shafts (metal). As soon as I can swing a few extra $$$, that's what I'm gonna do.
Rather-B-Huntin is offline   Reply With Quote
Old 01-17-2008, 07:39 PM   #3
Today i was crawling, it popped off, to this second its nowere to be found!
Old 01-17-2008, 07:42 PM   #4
TEAM MODERATOR
Reflection's Avatar
Just a little hint.....
74 threads in 0.71 seconds with the search feature. It's quite the topic in this section Seems nobody can figure it out Here ya go.....Driveshaft search
Theres allot more topics covered inside that little button as well
Reflection is offline   Reply With Quote
Old 01-17-2008, 07:43 PM   #5
TEAM MODERATOR
Reflection's Avatar
No,metal shafts aren't the best option.
Old 01-17-2008, 07:47 PM   #6
what if i tried to drill through the shaft and put a screw through so it wouldnt pop off?
Old 01-17-2008, 08:12 PM   #7
Axial now has little rings that slide on the driveshafts and stops this. I switched to stampede shafts W/ metal yokes.
dirtyal is offline   Reply With Quote
Old 01-17-2008, 08:18 PM   #8
Damn-I need a chump RT!!!
yotachump's Avatar
x2 on that, metal shafts are a waste of money.
yotachump is offline   Reply With Quote
Old 01-17-2008, 08:22 PM   #9
ok i might try and find some this weekend because im going to marion illinois
Old 01-17-2008, 08:33 PM   #10
a cheaper alternative to axial's fix is to just get some plumbing parts ( 30 cents each) that will fit over the drive shaft yoke like axial's ring
stublet is offline   Reply With Quote
Old 01-17-2008, 08:36 PM   #11
thanks! i never thought of that
Old 01-17-2008, 08:45 PM   #12
Location: where fear and common sense don't get in the way
I have the same shaft set-up on order. Looks to be the better system to run.
jagg is offline   Reply With Quote
Old 01-17-2008, 10:30 PM   #13
TEAM MODERATOR
Reflection's Avatar
Your looking in the right direction.
Guys,if the Pede shafts don't hold up.....put freakin Revo shafts on it and be done with it.
Old 01-17-2008, 10:34 PM   #14
Good idea right there with the revo shafts. Might have to try that.
You think the wheel axles or the center axles would fit better? Dunno if the center ones would be long enough from the revo.
MattG is offline   Reply With Quote
Old 01-21-2008, 08:04 AM   #15
Team Outlaw
bubbaracing's Avatar
Sup bud! I think the centers are too short! I'm gonna go by LH soon to see what I come up with? Or just might go with the Stampede with the metal yokes for now!
bubbaracing is offline   Reply With Quote
Old 01-21-2008, 08:17 AM   #16
TEAM MODERATOR
Reflection's Avatar
Pedes are the best easiest swap.
With Revo's,it's not the fact that the outputs are to short. They are 5mm,Revo's need 6mm. You can get 6mm adapters from RC4WD. New stainless steel 6mm outputs though eliminate the adapter An 81 tooth spur is the biggest I can run on this rig.
Old 01-21-2008, 03:07 PM   #17
i found a dumb solution or a half way solution for this.
1.take a strip of metal, trim it down to wrap around the shaft, leave a little extra.
2.bend the extra you left to a 90 degree angle.
3. drill a hole the two 90s, then put a screw through it.
you can also use for a disconnect.
Old 03-06-2008, 09:40 AM   #18
rc10 Shock clamps for the spring height adjustment should work for the collar.
ANUFSED is offline   Reply With Quote
