Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: big Battery questions?
Old 01-17-2008, 11:34 PM   #1
Default big Battery questions?
I just ordered a new battery that is 6 cell 4500 mah for my truck will it run that no prob? my truck has a 27 turn 550 big power motor but i need to buy a new esc so can i run another stock one??? because it doesn't change the voltage????
zeroskater9111 is offline   Reply With Quote
Old 01-18-2008, 08:33 AM   #2
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Voltage is determined by the number of cells, not the mah. Mah will determine how long it runs for (comparitively). IE under the same useage a 3000 should run twice as long as a 1500.
If you stock stuff can handle a 6 cell 1500 mah, it should be fine with a 6 cell 4500 mah.
Locked Up is online now   Reply With Quote
Old 01-18-2008, 09:14 AM   #3
Sweet thanks alot man i didn't think about it till after i payed for it but thanks for sortin that out
