| | #1 |
| Rock Stacker Join Date: Oct 2006 Location: Saskatoon
| Will sticky tack lock the diffs on a wk |
| Sponsored Links | |
| | #2 |
| RCC Addict ![]() Join Date: Sep 2007 Location: Westland, MI
| Not very well. Just get some JB weld it costs $5 at the hardware store or at an automotive supply ie pepboys, murrys, autozone. You wont be sorry. |
| | #3 |
| have you tried it |
| | #4 |
| Both axles of my WK were done be for it was even driven. Last edited by hitman46mod; 01-19-2008 at 07:40 PM. |
| | #5 |
| RCC Addict Join Date: Mar 2005 Location: Saginaw
| I would advise against sticky-tac, or hot-glue. The reason being is that it doesn't lock the diff effectively, nor does it give a smooth limited-slip effect as a fluid would. It'll hold for a bit, and then let go - leaving a big clump of material inbetween the gears that they will have to chew though, causing enough strain to eventually cause damage. If you want a removable option, either get a second set of diffs to lock, or buy a set of lockers. |
| | #6 |
| RCC Addict Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
| I started out with silly putty and have gone to Maximizers since then. The putty worked nicely and the lockers work a whole lot better! |
| | #7 |
| Pebble Pounder Join Date: Jul 2007 Location: USA
| If you are looking for a limited slip, I am using silicone ear plugs in mine. So far, it is working very well. But I am going for a bashing/trail truck not a hard core crawler so YMMV. |
| | #8 |
| Good idea Maggster! |
| | #9 |
| Damn-I need a chump RT!!! ![]() Join Date: Sep 2007 Location: Lost as hell.....
| lockers are 9.99 a piece just buy them;) |
| | #10 |
| Thread Tools | |
| Display Modes | |
