| | #1 |
| Newbie Join Date: Nov 2007 Location: gloversville
| first off whats the difference between 32 and 48 pitch gears and y are there different ones and second what would be a good spur and pinion tooth ammount to start at with 2 55t motors |
| Sponsored Links | |
| | #2 | |
| Picky Fab'r/Acetal Junky ![]() Join Date: Jul 2006 Location: Arizona Desert/AJ
48 pitch is a "finer" gear...which translates into more teeth per inch/cm/mm (depending on how small the gear actually is) around the circumference of the gear. I use 32 pitch spur/pinion on my 2.2 on a trans that comes as 48 pitch. I do this for strength...there's simply more "meat" on the teeth than with 48 pitch. On the question of why there are different one's...you can adjust your final gear ratio by simply switching spur & pinion gears. The higher the tooth count on the spur...the lower the gearing will be and visa versa. The smaller the tooth count on the pinion, the lower the gearing will be...and visa versa. Make sense? Last edited by Offroader5; 01-20-2008 at 05:07 PM. | |
| Thread Tools | |
| Display Modes | |
