01-24-2008, 04:06 PM | #1 |
Newbie Join Date: Jan 2007 Location: Cairns, North Queensland, Australia
| recommended upgrades for basher AX10
Im about to purchase an AX10 in the next few months intended for bashing & maybe a comp or 2, but i dont think they have comps where i live. Now, what upgrades would you recommend for a basher/non comp AX10. I have these upgrades in mind: AX10 kit w/Novak rooster crawler, fifty-five turn motor & HS645MG CKRC stage 2 Axial battery & servo plate Axial bent links for the front rcp straight axles & adaptors (no 4WS) rock claws LMK your thoughts & thanks in advance... |
01-24-2008, 04:45 PM | #2 |
Pebble Pounder Join Date: Feb 2007 Location: St.Marys County, MD
If you want a basher than you should get a 45t lathe, that is the motor I run and it will give you some wheel speed and power.
01-24-2008, 06:20 PM | #3 | |
Rock Crawler Join Date: Apr 2007 Location: portland
If you do plan to crawl, then all that stuff sounds good. I would include some aluminum front knuckles also (they bend too much for my taste). | |
01-24-2008, 06:41 PM | #4 |
I do plan to crawl with it, but just for thrills & excitement, not comp crawl with it. Because where i live there are no official comps, i do plan to 'beef' it up a little down the track, incase comps do emerge. Do u still suggest the above mentioned upgrades??
01-24-2008, 07:33 PM | #5 | |
Rock Stacker Join Date: Aug 2007 Location: Canada
01-24-2008, 10:18 PM | #6 |
| yes, all will help you crawl. We mainly use "bash" as a term for normal rc driving (like you would drive a normal monster truck, like an e-maxx). But if you do intend to crawl, yes all that stuff will serve its purpose. I have noticed that when bound up slightly, the front and rear knuckles will bend. So aluminum knuckles and possibly axle C's will be a good upgrade aswell. Or straight axle adaptors for the rear as you mentioned.
01-24-2008, 10:52 PM | #7 |
yeah i have no plans to make it rear steer, so i might aswell throw a straight asle in there. Grapegoat - cheers for that mate, ill keep the alloy knuckles & c's in mind. I would like to keep the upgrades to a minimum though, only get the upgrades i really need. if my knuckles break then ill def get alloy ones!! Ive also been looking at the Holmes Hobbies CrawlMaster Sport Mamba Max combo. I already have a mamba max fitted to my drifter & its the absolute best esc i have ever owned. Is BL really necessary for crawling, or will a brushed setup be fine? |
01-25-2008, 12:56 AM | #8 |
Pebble Pounder Join Date: Nov 2007 Location: Bay Area
u might also want to consider driveshaft upgrades, stock ones usually fail sooner rather than later
01-25-2008, 09:41 AM | #9 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
Get a better servo. I Started out with an HS-645 in my AX10, and it didnt have enough power for me,now I Have an Airtronics 94358Z w/200 oz of torque and I would still like more.
