01-27-2008, 09:24 PM | #1 |
Rock Stacker Join Date: Jan 2008 Location: westminster
| droop setup????
is it possible to do a droop setup with the stock axial shocks?
01-27-2008, 09:47 PM | #2 |
Quarry Creeper Join Date: Apr 2007 Location: Kapahulu Safeway
search
01-27-2008, 09:49 PM | #3 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
01-27-2008, 11:36 PM | #4 |
Quarry Creeper Join Date: Dec 2007 Location: Monterey, CA
| You're such a dick! heh-heh. Here's a quick answer that has some good pics of the setup. The search function is towards upper right hand corner of the main page of the forum. It's best to do a quick search first to see if the answer is easily found so as not to upset a$$holes like mtnyote. I know that itcan be overwelming and not always specific to your application, but it can usually get you a quick answer... droop setup cg? BTW, mtnyote, I wouldn't give you so much $hit if you didn't own that first course at the comp like you did!!! You da man! Cheers, Rob |
01-27-2008, 11:38 PM | #5 |
Quarry Creeper Join Date: Sep 2006 Location: Valpo
yes, anything is possible. the trick is figuring out how to set it up. just start with some springs from the crawler store and work it out from there. go to hardware stores looking for springs or even pens. do forget oil plays a big part. stop at a book store and read the books too. dont let people get you down because you can't find how to do it here. yes i ramble but you need to test things to figure out what works for your style.
01-28-2008, 11:29 PM | #6 |
