Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Links + Grease Lightning
Old 02-04-2008, 03:18 PM   #1
Default Links + Grease Lightning
So I was just looking through the forum and it looks like people are using grease lightning to strip the green off the links, where do you get it
Thanks guys
4X4 JEFF is offline   Reply With Quote
Old 02-04-2008, 03:30 PM   #2
Most people have been using the drain cleaner yellow bottle with tons of succes, that would be my recomendation. The Greased lightning in the white bottle is available at homedepot. EDIT: sorry i just saw that you tried the drain cleaner
xgerstandtx is offline   Reply With Quote
Old 02-04-2008, 03:38 PM   #3
ghetto fabulous newbie
use EZ off oven cleaner yellow cap. you buy it at the store
yotachump is offline   Reply With Quote
Old 02-04-2008, 05:26 PM   #4
Picky Fab'r/Acetal Junky
Offroader5's Avatar
You can also use Super Clean purple degreaser with fast results....just make sure you check it often, cause it works pretty fast and if you leave the parts in too long it will start to roughen the surface of the aluminum after it's removed the color. When you check the parts, rub on them a bit with a cotton rag and it will tell you if it needs more or not.
Offroader5 is offline   Reply With Quote
Old 02-04-2008, 06:03 PM   #5
support@rc4wd.com
roborg5000's Avatar
Thanks guys
Here you go buddy http://www.greased-lightning.com/pro...reLocator.aspx
roborg5000 is offline   Reply With Quote
