Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: LiPo usage in a Super
Old 04-08-2008, 12:15 PM   #1
Default LiPo usage in a Super
Im building a 17" pimp cane right now. Im running (2) 55 turn Integy motors with 9T pinons and Novak Superduty ESC. I was thinking of running (2) Lithium Polymer 910mAh 7.4V 15C Battery Pack. Is this gonna work, work good, or is it going to be a waste of money?
xzk7nr is offline   Reply With Quote
Old 04-08-2008, 12:37 PM   #2
Should work well, but I am a little confused. Are you saying you're going to run two packs on one esc at once? If so, make sure to check the rating of your esc. Good thing to check out the ratings on your esc in any case, you'll want to be certain you've got low voltage cutoff for lipos.
If everything checks out, that battery should work fine, although you might want to consider one with a higher mAh rating for longer runtimes.
ecoli is offline   Reply With Quote
Old 04-08-2008, 02:06 PM   #3
Holmes Hobbies
CD13's Avatar
Yea,I would run one battery and at a higher voltage that the esc can handle.
Name:  jan 23 (3).JPG
CD13 is offline   Reply With Quote
Old 04-08-2008, 02:37 PM   #4
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
One battery is best, but you will need a lot more amperage on a super. The rear motor will be stalling about 20-25 amps, so get something that can take it. Good old 2100 15C cells would work on your 65t motors.
JohnRobHolmes is offline   Reply With Quote
