Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: A question on bevel gears
Old 04-14-2008, 05:03 PM   #1
Southern buggy whore
ecoli's Avatar
Default A question on bevel gears
I'm planning on building up a rock racer with Axial axles, but using the stock kit (I don't need another esc, motor, etc etc.). So, I want to swap out the locker for bevel gears in the differential. The Axial bevel gears are not available anywhere that I've seen yet. However, I noticed HPI makes a set that at least on the surface look the same. Product number is HPI86014 (http://www3.towerhobbies.com/cgi-bin...?&I=LXBTA4&P=7).
Anyone know if this would be compatible? Not certain if bevel gears come in different pitches, etc. If noone knows, I guess I'll just pick up a set and be the guinea pig. Worst I can do is destroy additional gears
ecoli is offline   Reply With Quote
Old 04-15-2008, 12:33 AM   #2
Prick
rambuller84's Avatar
I read somewhere that someone dropped a whole WK diff in an AX I believe. Or was it the other way around?
rambuller84 is offline   Reply With Quote
Old 04-15-2008, 01:14 AM   #3
MWRCA'er
Mnster's Avatar
Post a Ad up.
I was looking a while back put a ad up and someone mailed me them for free.
Mnster is offline   Reply With Quote
Old 04-15-2008, 11:00 AM   #4
ecoli's Avatar
You're right, I think they are compatible. At least I know the lockers are.
Originally Posted by Mnster View Post
Post a Ad up.
Simple solution, I like Will try this route first, then maybe look at other options.
