Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Vf Dig Install
Old 04-16-2008, 01:03 PM   #1
digger
TOMCAT18T's Avatar
Default Vf Dig Install
I RECIEVED MY VF DIG YESTERDAY AND HAVE STARTED THE INSTALL. I NOTICED A COUPLE INTERESTING THINGS. FIRST, THE WHOLE TRANS HAS TO BE FLIPPED AROUND. THIS CAN PUT YOUR WIRES IN DESTRUCTION RANGE OF THE SPUR GEAR. THEN I NOTICED THAT MY REAR PUNISHER SHAFT IS NOW TOO LONG BECAUSE OF THE ROOM THE DIG IS NOW TAKING. I TRIED TO REPLACE THEM WITH THE STOCK ONES BUT THEY ARE TOO LONG AS WELL. SO I MOVED ON TO HOOKING UP THE SERVO AND LINKAGE. GOT IT ALL HOOKED UP, MADE SURE I TURNED THE AUX EPA ADJUSTMENT WAY DOWN ON MY Tx, TURNED IT ON. IT WORKED OK FOR A SECOND, THEN THE SERVO BLEW DUE TO BINDING SOMEHOW. IS ANYONE ELSE HAVING AS MUCH FUN AS I AM?
TOMCAT18T is online now   Reply With Quote
Old 04-16-2008, 01:09 PM   #2
YTC Team Driver
winkscrawler's Avatar
Instructions were posted on how to set them up from the manufacturer. Have you tried searching?
winkscrawler is online now   Reply With Quote
Old 04-16-2008, 01:19 PM   #3
I found the binding problem.If the bolt with the nut is tightened to tight the unit will bind.Cut the stock male driveline down.Hpoe this helps
speed goat is offline   Reply With Quote
Old 04-16-2008, 01:26 PM   #4
binaryterror's Avatar
VF even posted instructions
binaryterror is offline   Reply With Quote
Old 04-16-2008, 01:27 PM   #5
ive had all sorts of minor issues. First my vf front output sheared, killed 2- 225 servos. now i made a mount for a 645 (temporary plastic, have to drill the aluminum one this weekend) and im hoping it holds up better...shifts much smoother with the 645 too
nj05nismo is offline   Reply With Quote
Old 04-16-2008, 02:14 PM   #6
digger
TOMCAT18T's Avatar
Originally Posted by binaryterror View Post
THANKS FOR THIS LINK. WISH I HAD IT YESTERDAY.
Old 04-16-2008, 02:25 PM   #7
Keep it real
Tanis's Avatar
Why are you yelling(take your caps lock off)
Tanis is offline   Reply With Quote
Old 04-16-2008, 02:38 PM   #8
crash's Avatar
WHAT
crash is online now   Reply With Quote
Old 04-16-2008, 04:12 PM   #9
06 Super National Champ
JasonInAugusta's Avatar
JasonInAugusta is offline   Reply With Quote
Old 04-16-2008, 04:21 PM   #10
Crawling is a fad...
Nerve's Avatar
Typing in all caps ...
Is Almost As Annoying As People That Put Capital Lettters On Every Word That They Type Out Into A Post...
*sigh*
Nerve is offline   Reply With Quote
Old 04-16-2008, 04:41 PM   #11
It took me a little while to find my caps button when I first started posting, they cursed me and slapped me around till I finally press the "Caps Lock" button and they quit cursing at me.....They still slap me around a little.......But I like it
JBHardwear is offline   Reply With Quote
Old 04-17-2008, 10:38 AM   #12
Billet Freak
billet works's Avatar
What are the odds I'd be trolling around and find this post .
Let me make this very clear. If anyone has trouble like this, figuring out how to get theirs set up correctly, PLEASE contact us directly so we can work you through it. Instead of starting random threads, come to the source or do some research to find your answers. VF encourages it's customers to let us help you through your problems. We do not want anyone to get frustrated with one of our products!
Please do not PM your problems as my pm box stays overloaded as it is. Keep in mind we are a small shop and are unable to be logged into the boards all day...if we did nothing would get done in the shop. Just shoot an email to brock@visionaryfabrication.com and we will definitely get you taken care of!
Don
VF
billet works is offline   Reply With Quote
Old 04-17-2008, 10:56 AM   #13
RIP Buster
badger's Avatar
Don
VF
Don,
Keep in mind your in the Newbie General forum where members bitch first then read the instructions.
badger is offline   Reply With Quote
Old 04-17-2008, 11:04 AM   #14
don has taken care of me when i called/emailed them when my front output snapped. Replacement part should be here today or tommarow given when they shipped.
Old 04-17-2008, 11:48 AM   #15
I joined the Band!
Default Don't have one yet?
Now you could win one of these baby's!
jaxcoffee is offline   Reply With Quote
Old 04-17-2008, 12:03 PM   #16
Originally Posted by badger View Post
Don,
You're so supportive, that it's oozing out... no wait that's something else oozing out. heh-heh...
rdtshaw is offline   Reply With Quote
Old 04-17-2008, 12:29 PM   #17
Hey Don, any chance you all will machine another servo mount? I had to ask here as this is kind of an up in the air thread. Anyway, I have no machining capabilities and would love that option. I might even throw a 5955 on tha dig if there were amount.
O.C.D. is offline   Reply With Quote
Old 04-17-2008, 07:24 PM   #18
odd placement for this type of post....
p!nK
mrpink is offline   Reply With Quote
Old 04-17-2008, 08:46 PM   #19
very easy to make a mount...all you need is a grinder (or dremel) and a drill...nothing too magical about it. Just need to cut some angle aluminum and drill a few holes and your good to go
pink-its because you can now win one if you win the coffee thing
Old 04-17-2008, 09:06 PM   #20
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
Maybe a odd posting location but look at those friggin prizes...
Stormin2u is offline   Reply With Quote
