Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Droop Setup - Sprung Setup - What The ?
Old 04-17-2008, 12:36 AM   #1
Default Droop Setup - Sprung Setup - What The ?
I'm new to this whole crawling thing (obviously) - and I just read some folks talking about a "droop setup" and a "sprung setup" - what does that mean?
rctoyguy is offline   Reply With Quote
Old 04-17-2008, 01:01 AM   #2
in a droop set up, the rig sits with the shock compressed and the axle drops away from the chassis. in a sprung setup, the shocks are extended and the tires/axle comes UP to the chassis. a semi droop setup will allow the axle to rotate without raising or lowering, providing a more stable ride, but harder to setup and get right.
mysharona is offline   Reply With Quote
Old 04-17-2008, 01:09 AM   #3
Front is full droop rear is full sprung. Its still a project so dont knock it
Generally most people run a spring inside a shock setup for droop so it extends in a controlled manor. Semi dropp usually you have a internal and external spring that kinda fight each other to control ride height and the way it reacts. Obviously oil is used in all setups.
rocktoy is offline   Reply With Quote
