| | #1 |
| Rock Stacker Join Date: Mar 2008 Location: WLA
| i read so much anti squat / pro squat stuff and still don't know squat. which is this ? on flat concrete give it full power from a stand still - front of rear differential goes up. truck going forward |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Jan 2007 Location: Secret Crawl Location Deep In England
| pics? |
| | #3 |
| Quarry Creeper Join Date: Feb 2007 Location: Tokyo, Japan
| ykcor...what you are desrcribing IS squat...Think of sitting down to poop Pro-squat is not an expression i am expert on but i can imagine it might be crawler-specific, (again maybe not) meaning that you WANT the truck to squat, (ie, load up its rear) in a certain situation, maybe to get a start on a climb or whatever...hope this helps... |
| | #4 |
| Rock Crawler Join Date: Apr 2007 Location: St. John's
| Does anybody on here know about diddly-squat? (Sorry its Friday afternoon and I couldn't resist. I'll go away now! |
| | #5 |
| | #6 |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
| What's the set up? Leaf sprung? |
| | #7 |
| super soft springs from ckrc, limiter inside the shock . stage 2 bend links in rear with longer links up top and the diff angled up a little bit. |
| | #8 |
| Newbie Join Date: Feb 2008 Location: Where ever the Army puts me.
| Sounds like what he is talking about is when he gives the truck gas the pinion is lifting up on the rear dif. Almost like the rod ends for the links are worn out. |
| | #9 |
| Get off my lawn! ![]() Join Date: Feb 2005 Location: Cleveland, OH
| Could just be fawked-up link geometry, too. If the upper links are too long, you'll have pinion-angle changes like that. Does the pinion angle change as you cycle the suspension up and down? |
| | #10 |
| Rock Stacker Join Date: Apr 2008 Location: auburn
| i would have to say pinon angle is to high adjust back down and try again ------------------------------------------------------------------------when you think your done its time to tear it apart and rebuild it |
| | #11 | ||
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
The way I'm reading your posts,your describing axle wrap. There should be ZERO axle wrap with any link suspension. Leafs,yes,you'll have axle wrap....no way around it. Quote:
The rear pinion angle of my super,it's pointed UP at about 45 degrees and the shaft itself is level with the ground while sitting at rest. Does it change under acceleration? | ||
| Thread Tools | |
| Display Modes | |
