| | #1 |
| Rock Crawler ![]() Join Date: Jan 2007 Location: Northern Wyoming
| searched but never found many definite results. Just got an edge built AX10 and looking at either dig or rear steer. No comp or anything around here in northern Wyoming so thats not a factor, more or less just fun the the yard and while out wheelin the 1:1. Whats the best bang for the buck, rear steer or front dig? I've got a dig type setup in my 1:1 and its nice but most the time rear steer would be more practical in it but maybe not so in the RC version? |
| Sponsored Links | |
| | #2 |
| I wanna be Dave ![]() Join Date: Jan 2005 Location: Hueytown, Alabama
| Dig. It not only helps you turn sharper than you could with rear steer, it will allow you to get traction on verticals without allowing the rear to run under the truck. |
| | #3 |
| RCC Addict ![]() Join Date: Aug 2007 Location: Rohnert Park
| If you're just running for fun, put on the rear steer. Dig for comps! |
| | #4 |
| Quarry Creeper Join Date: Sep 2007 Location: Rice field HELL!!!
| The quick set up is to run rear steer. I have rear steer on all my rental trucks. If your using a pistol grip radio you can buy a reversing Y adapter and your wheels will turn the same way. I recently purchased a dig and I have not installed yet, but I hear it can take and hour to 4 hours tuning it in. Either way you have to buy another servo, so if your not comping I would go rear steer, just my opinion! |
| | #5 |
| Rock Crawler Join Date: Apr 2007 Location: Denverish
| Dig. Its more versatile, and will allow your truck to do more things than rear steer will. Also, as mentioned before, its comp legal. |
| | #6 | |
| Rock Crawler Join Date: Apr 2008 Location: Fondy, WI
| | #7 |
| Pebble Pounder Join Date: Jan 2007 Location: Isanti, MN
| if you don't have a radio yet, get a spektrum DX6. it is a stick airplane radio, whith 6 channels and no frequency conflicts. only 176$. with that and a couple 35$ hitec 645 servos you can have both dig, and rear steer. i've been told that once you get used to the stick radio you will be a better driver with it than with a pistol grip. |
| | #8 |
| RCC Addict ![]() Join Date: Dec 2007 Location: Calgary
| would it be pointless to run both, rear steer and a dig? |
| | #9 |
| you may need a more powerful BEC with 3 servos, but i think that the dig would be good to help you climb, and turn, or in some situations the rear steer may help you wiggle your way out of a tight spot. if you only do one i would reccomend dig. dig is legal if you ever compete. and rear steer may be a little more difficult to coordinate to manuver than just activating the rear lock. |
| | #10 |
| Newbie Join Date: Jun 2007 Location: New Milton
| | #11 |
| | #12 |
| rear steer on rear axle, and then mount the dig servo in the chassis. on the r2 dig tranny you can mount a servo on the tranny. |
| | #13 | |
| Pebble Pounder ![]() Join Date: Mar 2007 Location: Kalispell Mt
if I had dig AND rear steer... hmmm | |
| | #14 |
| Rock Crawler Join Date: May 2007 Location: lacey
| I find the DIG setup much more useful than the rear steer on my other rig. |
| Thread Tools | |
| Display Modes | |
