05-25-2008, 06:28 AM | #1 |
RCC Addict Join Date: Feb 2006 Location: ccxc
| Wiring BEC
So I am going to run a CC BEC and a Tekin FXR. How do I wire the BEC? Do I need to disable the onboard BEC and if so HOW? Any tutorials?
05-25-2008, 03:43 PM | #2 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
When I Installed Mine I Soldered The Pos+ From The Bec To The Pos+ On The Esc To A Deans Plug . Neg The Same And Then Take The Red Wire Out Of The Esc's Rx Plug . To Adjust The Voltage You Need A Castle Link. Hope That Helped
05-25-2008, 08:04 PM | #3 |
Quarry Creeper Join Date: Mar 2006 Location: Eastern North Carolina
I wire mine up the same as stated above. I always remove the red wire from the ESC's RX plug. I also cut off the on/off switch on my comp crawlers that run LiPo. I do that for two reason: first, it forces me to always unplug the pack, and second, the switch can't fail or get turned off if my truck rolls. The cleanest install is usually to just wire it to the ESC's power wires right at the plug. |
05-25-2008, 08:34 PM | #4 | ||
RCC Addict Join Date: May 2008 Location: On the rocks
05-26-2008, 03:13 PM | #5 |
Rock Stacker Join Date: Apr 2008 Location: Norcal
JW, why do you want a BEC with the fxr. Doesn't the internal bec already provide 6 volts?
05-26-2008, 03:15 PM | #6 |
Pebble Pounder Join Date: Dec 2007 Location: Canby, Oregon
Its not the volts he wanting to improve its the amps
