View Poll Results: Will this be stupid | |||
Yes | 6 | 26.09% | |
NO WAY | 9 | 39.13% | |
depends on what it looks like | 8 | 34.78% | |
Voters: 23. You may not vote on this poll |
06-07-2008, 08:48 AM | #1 |
Rock Stacker Join Date: Apr 2008 Location: Oregon City
| Wanna build a LOW LOW buget scaler
I was thinkin of taking a spare chassis and cutting it just above the three link mounts. Then braze frame rails and cross members in then i would use the left over shock mounts and trim them down and braze them over the top of the axles? What do you think. |
06-07-2008, 09:28 AM | #2 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
so you are saying basically take this: .. \....../ ....\__/ and turn it into this? _\_______/_ ......\__/ if you are going to go to that much effort, why not just use the brazing torch to heat up 1/2" square tubing and bend frame rails, then cut the tube in half? you get a matched pair of rails and it should come out less ghetto. Last edited by hairba11; 06-07-2008 at 09:30 AM. |
06-07-2008, 03:46 PM | #3 | |
kind of??? | |
06-13-2008, 10:00 AM | #4 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
it sounds like you're kind of describing a mfm chassis
06-13-2008, 10:30 AM | #5 |
Rock Crawler Join Date: Feb 2006 Location: jacksonville beach
thats the way i've done em' bending square tube and then i cut it down the middle with a band saw it took a few tries, but i would suggest drilling your holes BEFORE you cut it in half, it makes every thing actually match up a little better. |
06-15-2008, 11:15 AM | #6 | |
Rock Stacker Join Date: Jan 2008 Location: Clay, Alabama
Is the 1/2" stock pretty easy to find? Thanks. | |
06-15-2008, 11:26 AM | #7 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
do you have a Lowes or Home Depot close... they have a metal assortment in the hardware section... for 1/2" square tube, it'll be around $5 for 3 ft... or if you have a welding shop close by... you an get it alot cheaper... the shop in my town charges about 70 cents a foot
06-15-2008, 04:13 PM | #8 | |
Quarry Creeper Join Date: Jan 2006 Location: Henderson
Is your 10" Delta a bandsaw or a tablesaw? If it is a bandsaw,it will work just fine. If it is a tablesaw,I wouldn't want to try it. | |
06-15-2008, 05:05 PM | #9 | |
Newbie Join Date: Aug 2007 Location: BC
Guesstimate where you will put some crossmembers and at least drill those before cutting in half. My last project I just used a jigsaw and it worked just fine. Take it slow with a new metal bit and you have a super cool cheap chassis. Good luck! | |
06-15-2008, 07:19 PM | #10 | |
Y'all talk about drilling holes. For the crossmembers I had planned to use flat barstock and braze them. Is that a good idea. | |
06-15-2008, 08:03 PM | #11 |
Pebble Pounder Join Date: Apr 2008 Location: Indiana
If it's stupid...and it works...it ain't stupid.
