06-28-2008, 01:33 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Carlisle
| I forget (brain fart)
what will get me more wheel speed a pinion with more or less teeth?
06-28-2008, 01:36 PM | #2 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
more
06-28-2008, 01:39 PM | #3 |
Rock Crawler Join Date: Jun 2007 Location: Great Britain
Less teeth more acceleration, more teeth higher top end.
06-29-2008, 06:02 AM | #4 |
Quarry Creeper Join Date: Mar 2006 Location: Eastern North Carolina
As people have pointed out for you, a larger pinion (more teeth) will increase top speed; it will also decrease run time and make the motor run hotter. A smaller pinion will do just the opposite on all accounts. Keep mind, that changing the spur gear size works the opposite as changing the pinion. For example, a smaller spur gear will increase top speed. On a crawler, increasing the pinion size may or may not increase wheel speed. It will increase top speed, but out on the rock it might hurt more than help. If you want more wheel speed, I suggest switching to a 3S LiPo if you haven't already. Most people who increase voltage and then run low gears (small, small pinion) have the best of both worlds--plenty of torque and all the wheel speed the need when the need it. |
