07-07-2008, 04:15 PM | #1 |
Pebble Pounder Join Date: Apr 2008 Location: fresno
| Couple nooby questions
1. What all do i need to get rear steer besides the rear steer kit and a servo? SOLVED 2. Are there any 80's toyota pickup bodys available ANYWHERE? SOLVED 3. Is there a final date on when the scorpion color packs? i read late July but im in need of them now. Last edited by 88toyota88; 07-10-2008 at 03:45 PM. |
07-07-2008, 04:39 PM | #2 |
Pebble Pounder Join Date: May 2008 Location: Florida
rpp hobby has a 79 yota
07-07-2008, 04:53 PM | #3 |
The Hilux?
07-07-2008, 04:59 PM | #4 |
yes
07-07-2008, 05:00 PM | #5 |
nice. thanks a bunch!
07-07-2008, 07:43 PM | #6 | |
RCC Addict Join Date: Jun 2008 Location: Fresno
a y-harness w/ a reverser or if you're willing to open up ur servo to do a little soldering a standard y-harness you might want to check out my thread about an issue i had when i installed my rear steer rewireing reversing servo question from what i remember ur running a rtr scorpian you might also need to get a couple more things. since the rtr uses a locked rear axle ur gonna need things like a set of new wish bones c hub some berrings if anything i can give you an exact list of what you need before ur rear steer is up and running. * im at work right now and dont know all the parts off the top of my head, but i do have an invoice at home on what i bought. Last edited by NeXt559; 07-07-2008 at 07:49 PM. | |
07-07-2008, 10:54 PM | #7 |
things parts ur going to need for rear wheel steering if ur currently running a rtr ax10 axa864 - m3x8mm tapping binder head axa80018 - hardware parts tree axa1230 - bearing 10x15x4mm ax30420 - solid axal dogbone 6x74mm ax80004 - hub set ax80012 - c hub carrier set axa1221 - bearing 5x11x4mm axa865 - m3x10mm tapping binder head btw richard over at cycle arts, off of clinton and 99 should stock these parts if u want to get them locally. if i missed anything he should be able to help you out. you should bring your rig w/ u just n case though *sorry, dont want to take business away from the vendors but i noticed that 88toyota88 lives in my area |
07-08-2008, 02:08 AM | #8 | |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
07-08-2008, 07:36 PM | #9 | |
07-08-2008, 11:40 PM | #10 | |
sorry to go off subject but... i think i know who your talking about havent gotten to meet them yet but richard told me that i missed them by like 5 minuites when i went there yesterday. do they build 1:1 crawlers? | |
09-11-2008, 08:54 PM | #11 |
Newbie Join Date: Jul 2005 Location: Alexandria
Could I just buy another front axle assembly and use it for the rear or is there something different? Jon |
09-11-2008, 09:30 PM | #12 |
Quarry Creeper Join Date: Feb 2008 Location: New Rochelle
| rear steer is no good.
dont get rear steer. Thats a thing of the past. If you want to make it comp worthy get dig. In the end it will cost around the same as rear steer if you have to do all those axle mods. Also have all four wheel move at the same time getts really annoying. I was all for it till I watched videos of it. if you want comp statues use DNA dig
09-11-2008, 11:06 PM | #13 | ||
rear steer = fun dig = more capable crawler | ||
09-12-2008, 12:06 AM | #14 |
Newbie Join Date: Sep 2008 Location: Port Alberni, BC
so you are able to just buy a replacement front axle and install it in the rear, and have no problems at all? interesting... i think i might do that, i think it would be cheaper in the long run
09-12-2008, 09:30 PM | #15 |
| well of course going to need a 3rd channel, extra servo, servo plate, servo mount and rear steer kit for the steering links and rod ends
09-12-2008, 09:48 PM | #16 |
so its not really cheaper then. i'll figure it out ps. sorry to thread jack :P |
09-12-2008, 10:27 PM | #17 |
Thanks NeXt559 for answering my question, I do appreciate it. I do realize that dig would be better for a comp rig AND rear steer is not legal BUT I'm building this for me and not to compete. Heck, I'd be extremely lucky to even find a place to run the truck around here, I'm hoping my LHS builds a course so I'll have a place to play but until then I'm going to just have fun around the house with the 4ws and maybe even build a scaler. Of course once a course is built it will then either be converted to a comp rig OR just add to the fleet. As for the 3rd channel, I already run a Futaba 3pk so I have plenty of options for different mixes as well as a dial to use for indy rear steer. Anyway, thanks again! Jon |
