07-11-2008, 12:25 PM | #1 |
| losi shock question
I'm getting some used losi shocks. I like to rebuild them. I was looking on http://www.losipartshouse.com website and saw there, was quite few differnent shock pistons. Whats the diff between numbers and colors ? what they mean ? which ones should I get ? |
07-11-2008, 12:37 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
The different colored pistons have different sized holes in them. I ran the black (#57) pistons for a while with very good luck. The number on the piston packaging is just telling you how big the holes in them are. Here's a chart that'll tell you what the decimal equivalent is for the numbers on the pistons. http://bobmay.astronomy.net/misc/drillchart.htm |
07-11-2008, 12:43 PM | #3 | |
Are you running different pistons now ? | |
07-11-2008, 12:47 PM | #4 |
07-11-2008, 12:51 PM | #5 | |
Btw is there any tricks to building them or anything to make them better ? Sorry for the newb questions, I never mess with losi shocks before... gotta start somewhere. | |
07-11-2008, 12:55 PM | #6 |
| They are the easiest shock to build IMO. The only advice I have is grease the seals and install the shock shaft from the snap ring/piston side. If you slide the threaded side through without deburring them, it can tear the seals which will cause them to leak.
07-11-2008, 01:18 PM | #7 | |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
Rear: Right rear red #56 with 30wt LOSI, left rear black #57 and 35-40wt LOSI | |
