07-12-2008, 06:31 PM | #1 |
Newbie Join Date: Jul 2008 Location: Albuquerque
| Newb here, need some expert review of my RCer build! Ok guys I have done some research and have come up with the following parts to build my rock crawler. However what I need from you is your opinion and your knowledge on any possible problems with my build. Speak loud and plainly please!! Ax90004 AX10 Scorpion ARTR (almost-ready-to-run) AX10 Aluminum Adjustable Split Battery Axle Plates 8 Cell 1500 AX10 Crawler Pack With Tamiya Plug PHX-LINK Castle Creations Castle Link Programming Kit MMB-Sidewinder Esc with Drag Brake Novak Crawler Brushless Motor 21.5 Spektrum SR3000 Dx3.0 Receiver Castle Creations 10amp Bec Unit MG946R high torque servo If there is anything else I should add to the list like a capacitor to clean up voltage and/or other items I am not aware please let me know!! |
07-12-2008, 07:09 PM | #2 |
Rock Crawler Join Date: Aug 2007 Location: Tucson
dump the tamiya plugs and go with deans
07-12-2008, 07:14 PM | #3 |
Pebble Pounder Join Date: Dec 2005 Location: Metro NYC
the novak motor is sensored and will not work w the sidewinder... get a 55t-65t brushed motor instead. |
07-12-2008, 11:01 PM | #4 |
Thanks for the info guys, I need to do some more forum searching..I totally missed that the Novak 21.5 isn't compatible with Sidewinder. Again thanks for the help. |
07-12-2008, 11:45 PM | #5 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Hit up holmes hobbies for all your crawler motor needs. |
07-12-2008, 11:55 PM | #6 |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
| GET DEANS PLUGS!!! I HAVE MELTED TO MANY TAMYIA PLUGS. ALSO DEANS HAVE LESS RESISTANCE! ALSO LOTS OF PEOPLE LOVE THE HOLMES HOBBIES PULLER MOTORS. HAS ANYONE TRIED A NOVAK BRUSHLESS WITH A CASTLE ESC?IT SHOULD WORK.THE SENSOR WIRE IS SENDING TO THE ESC NOT ESC TO MOTOR! |
07-14-2008, 10:11 PM | #7 |
Rock Crawler Join Date: Feb 2007 Location: In A Nut Shell
A sensorless controller can run both sensored and sensorless motors. A sensored controller can only run sensored motors. and yes sensorless controllers will drive sensored motors so yes you can use novak brushless with the mm but why id just get the goat system |
07-14-2008, 10:45 PM | #8 |
Sensorless works great at higher motor rpm but not so good at the low end. Just thought I'd add that into the mix.
