07-13-2008, 06:12 PM | #1 |
Newbie Join Date: May 2008 Location: la puente
| msd topgun wheels
guys did you drill a hole in your msd topgun? how many hole? |
07-13-2008, 08:35 PM | #2 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
I drill four 1/16th size holes in each bead lock. Every one is different though and there is no right way or size hole to do. If you search the forum you will find a few threads on the topic.
07-14-2008, 11:08 AM | #3 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
I didn't want to ruin the finish (even though you really can't see a hole going through the side) so I searched here and did the mod where you drill a hole into 2 or 4 of the screw holes on the back face of the wheel. Instead of mounting all 8 screws mount 4. Drill a hole or two into the screw holes from the inside of the rim and they act as the airway. If you want to seal them up just put the other screws in. Works great and didn't ruin the finish of the wheels.
