07-16-2008, 06:07 PM | #1 |
Rock Crawler Join Date: Aug 2005 Location: Lufkin, Tx
| Noob VF dig question?
Ok I had a thought today while I was looking for a 3 way switch for my remote. The dig is gonna have 3 postions so when the dig is in 4wd mode would the switch be switched on to one side or in the middle? A friend of mine just set his dig up with the MX-3 remote and the way he has his is when the switch is all the way up the truck is in 4wd. He moves it one like it is in front dig with rear locked. I am thinking the way it should be set up is when the switch is in the off position the truck would be in dig with the rear freewheel. But to have it in 4wd the servo would be turned on and sitting in one position for a long time. Wouldnt that burn up the servo pretty quick and run the battery down quicker as well?
07-16-2008, 09:05 PM | #2 |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
Don't think about it as on and off as far as the servo goes, because your switch on your tx isn't turning anything off and on, it's simply changing the position. A three way switch should be one way for 4wd, middle for freewheel, and the other way for dig. I never had any luck getting the mini servo's setup with the end point adjustments before they fried, so I went with a 645 on my VF, but when you set the end points make sure you adjust it to where it's in the postition you want it in but the servo isn't humming, and you'll be fine.
07-16-2008, 09:12 PM | #3 | |
07-16-2008, 09:16 PM | #4 | |
07-16-2008, 09:18 PM | #5 |
Newbie Join Date: Feb 2008 Location: Beacon
Make sure you have very fine control of all 3 positions, end point adjustments. Very important. That little 225 does not like to be in a bind situation, I just cooked one I thought was fine, it wasn't.
07-16-2008, 10:45 PM | #6 |
Quarry Creeper Join Date: May 2006 Location: Volcano, Hawaii
Another thing with the mini servo, if you are running a external bec that could also stress it unless you can turn the voltage down to 4.8. Seems like it can tolerate being bound up for longer periods of time if you're not running a full 6 volt bec into the mini servo. However, keep in mind that you do want a full 6 volts for your steering servo.
07-17-2008, 03:05 AM | #7 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
the best way to set it up is to start with the endpoints really close. Say 25-35% then go out from there.
07-17-2008, 06:31 AM | #8 |
RCC Addict Join Date: Sep 2007 Location: WHEAT RIDGE, CO
END-POINTS are critical for the set-up. I've been using one 225 since i got my VF, and have had NO troubles. Follow the instuctions for the set-up of linkage etal.. and you should not have any troubles. If you don't have epa adjustments, rig to only do 4wd and lock, much easier to set up |
07-17-2008, 10:37 AM | #9 | |
07-17-2008, 11:55 AM | #10 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
Now that last question was a good one - I am watching for responses to that.
07-17-2008, 12:17 PM | #11 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
Your radio (TQ3) does not have end point adjustments in stock form. See sticky in electronics section for that mod.
07-17-2008, 01:15 PM | #12 |
| Ohhh......Good catch on that one. I was thinking MX3 but now I realize that was your friend's setup. Definately check into the electronics section on what all you have to mod on that TQ3, or the servo's wont last more than a minute or so.
07-17-2008, 02:07 PM | #13 |
I have a airtronic MX-3 now too. I bought it off ebay a couple weeks ago for $50. |
07-17-2008, 02:11 PM | #14 |
07-17-2008, 02:24 PM | #15 | |
Rock Crawler Join Date: May 2007 Location: lacey
go out and buy a Y harness. plug both servo and bec to harness. plug harness into receiver and pull the red wire from the plug that goes to the receiver from the Y. leave the speed control wire intact, and your good to go! | |
07-17-2008, 03:04 PM | #16 |
Robert: what mysharona about wiring the BEC is perfect, but you only need to use it for the steering servo. The 225 pulls so little there is no need for a BEC. The steering servo prob has much more torque and is being used alot more and under a bigger load. Wiring with the "Y"harness will isolate the steering servo, and will not shut the system down if you get the steering bound up. Let the ESC do the work for the 225. And no you do not have to up the voltage to the dig, stock is plenty. Again end-points are critical!! |
07-17-2008, 03:09 PM | #17 | |
The idea is to lower the voltage going into the 225 to 4.8, which you can do with a second ccbec. A friend of mine has his set up to run the steering servo off of the ccbec and the 225 of the esc bec. However if you're running the novak rooster, I would run the steering servo on the esc bec, and use the ccbec for the 225 with it programed to output 4.8volts. In my setup I have the rooster's bec powering both my steering and 225 dig servo, and I haven't had any problems with burning my 225(I'm knocking on wood right now). However, as soon as I do burn my 225, if that ever does happen, I'll be setting it up with a ccbec to turn down the voltage, and running the steering servo with the rooster's bec. The other option is to run two of the ccbec and program them accordingly. Last edited by crazy_kanaka; 07-17-2008 at 03:13 PM. | |
