08-01-2008, 10:28 PM | #1 |
Pebble Pounder Join Date: Jul 2008 Location: ov, sacramento
| droop question
when im at certain obstacles it seems like theres more tipping going on, like the rear raises up as i go up an incline almost like a dig.it seems like if there were normal shocks on it that it would want to do this.and flexes a little diffrent,can someone confirm this? and also would shock placement effect this? because they are alot more inward compared to a standard setup |
08-03-2008, 08:57 AM | #2 |
Rock Crawler Join Date: Apr 2008 Location: Rancho Cucamonga
Try a thicker shock oil or internal spring.
08-04-2008, 02:24 AM | #3 |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
are you running an internal spring and it sucks the wheel back up? thick as oil will slow this down. p.s. super thick oil 100wt and above |
08-04-2008, 03:37 PM | #4 |
ya im using mini t springs. and yes its sucking the rear up smetimes. so some like 120 wt?lol |
08-04-2008, 03:57 PM | #5 |
I've gone to tiny internal springs UNDER the piston, and adding weight to the rear. This helps to keep the tires planted when on a sideways crawl. 7oz all the way around. I let the servo and battery pack take care of the front. 100wt oil as well.
08-04-2008, 04:04 PM | #6 |
ya its on a super if that makes a difference and the front has plenty of wieght on it.lol
08-05-2008, 02:17 AM | #7 |
you need to try some 1000 wt oil to slow things down on a super. i have 100wt in mine and it doesn't do much.
08-05-2008, 02:42 AM | #8 |
08-05-2008, 03:48 AM | #9 |
Rock Crawler Join Date: May 2007 Location: Norwich
I run 3000 wt (mugen silicone diff oil) in my 2.2 and 5000 in my super. Works great.
08-06-2008, 12:30 AM | #10 |
try to bum some of a friend to see if you like it.
