Springs So i bought a package of team associated springs for my ax-10 RTR and just wondering which ones would work the best for rock crawling the springs are 1.90 spring rate 2.10 spring rate 2.55 spring rate 2.75 spring rate 2.95 spring rate I started out with the 2.55 in the front and the 1.90 in the rear but not really sure if that would be a good setup! Let me know what you think of if i got the wrong springs all together! Thanks guys |
Most go soft on the front, then a little stiffer on the right rear, and a little stiffer on the left rear because of torque twist |
I'd start with the 1.90 front and the 2.55 rear. |
I'm not sure of the rates, but on my axial test rig, the extra soft front springs and stock rear springs are really working the best out of everything that I've tried so far. It's a great starting point. |
Springs Just wondering, will these springs fit T/E Maxx shocks? If they will, do you know if any of them are softer then the stock 'Maxx' springs? Also, what was the part number for these springs? Thanks for your help. |
